Author Topic: pcv route  (Read 5088 times)
Offline mikewb
pcv route
« on: August 11, 2008, 07:14:15 pm »
i need a place to hook my pcv valve. i had it run from front on my edelbrock carb but switched it for a holley now no place to run it. soo theres oil being pushed out front of my block somewhere.
Offline eventhorizon66
Re: pcv route
« Reply #1 on: August 11, 2008, 07:15:53 pm »
There is a vacuum port for PCV on a Holley.  I believe it's under the rear float bowl on all holleys.
« Last Edit: August 11, 2008, 07:19:12 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline mikewb
Re: pcv route
« Reply #2 on: August 11, 2008, 07:17:42 pm »
I have my brakes hooked up there
Re: pcv route
« Reply #3 on: August 11, 2008, 07:25:09 pm »
I don't see anything wrong with using a 3/8" tee there.
Offline 82Shortbed
Re: pcv route
« Reply #4 on: August 12, 2008, 01:25:13 am »
Ditto to that.  I had an '80 malibu where I had the brakes and PCV lines T'd together.  I liked the edelbrock when I swapped it then because everything had its own port!
'82 Custom Deluxe
350, 882s, stock cam...For Now
Re: pcv route
« Reply #5 on: August 12, 2008, 11:20:14 am »
Depending on the intake you have you could move the Vacuum for the brakes to the manifold if you didn't want them together, otherwise you need to Tee it.
