Author Topic: TBI swapping  (Read 3724 times)
Offline ponyracer
TBI swapping
« on: August 18, 2008, 08:49:22 am »
Ok here goes, I have a 95 sub with a 350tbi/4l60e combo. I also have a 78 swb 2wd truck w/350/350 combo. I was going to swap the engine/tranny/wiring/dash from the sub into the 78 but I really don't like the dash in the 95. So I'm planning on doing the sub/blazer gastank swap, fuel lines, engine/tranny, cooling, and as much wiring as needed to make her run.
Now the question, where do I break the harness??? Is there a junction block so you can you have comp and the engine side and thats it or should I look for an aftermarket harness?? I don't want a huge rats nest of wiring because this will be a DD. And idea of mpg with this swap?
I'm in iraq at the moment so any vehicle specific questions will have to wait but I'll be home soon!!!!!!
Thanks
Re: TBI swapping
« Reply #1 on: August 19, 2008, 11:44:56 am »
Are you wanting to know were you can cut the harness so it will be a stand alone?
I haven't ever looked at a 95, so I can't say for sure, but if you had a schematic for it that would simplify alot.  You can probably get a schematic from the dealership, that is where I got mine.
I would say you should get 17/22mpg on that setup.
Offline ponyracer
Re: TBI swapping
« Reply #2 on: August 22, 2008, 09:50:42 am »
Ya that's exactly what I'm trying to do. I'll have to look around for a schematic. I'm not to great at wiring though!!
