Author Topic: door glass run  (Read 5831 times)
Offline 8oStEpc10
door glass run
« on: August 18, 2008, 03:14:35 pm »
OK I have a 80 c/10 stepside and i put new doors on and they were from an 85. I have a new rubber kit for the cab and the glass run seal has two little clips at the top and they dont line up with the holes should i use 81 and up seal or does the 73-80 work?
Re: door glass run
« Reply #1 on: August 19, 2008, 11:38:07 am »
There are 2 different run channels.  81-91 and 73-80.  If your doors are 85, you will want the former to match.  The 73-80 will probably work, but....
Window scrapers you will HAVE to get 81-91 versions.
Offline comp
  • 76-77-78
Re: door glass run
« Reply #2 on: August 19, 2008, 04:13:09 pm »
 good info to have  ;D
Offline 8oStEpc10
Re: door glass run
« Reply #3 on: August 19, 2008, 05:55:06 pm »
What are window scrapers?
Re: door glass run
« Reply #4 on: August 19, 2008, 07:29:10 pm »
The piece running horizontally across the door on the outside and inside (connected to the door panel)
Offline comp
  • 76-77-78
Re: door glass run
« Reply #5 on: August 19, 2008, 07:30:44 pm »
he got it
Offline 8oStEpc10
Re: door glass run
« Reply #6 on: August 20, 2008, 03:26:22 pm »
Hey thanks guys im new at this site and im just trying to get this project off the ground. its my daily driver and someone hit both doors long ago and I just got done prepping the doors shaving them and now pu tting them on and back together so thanks again..
