Author Topic: any way to increase gas milage  (Read 15337 times)
Offline tobysoldblue
Re: any way to increase gas milage
« Reply #15 on: September 13, 2008, 09:16:27 am »
I know a performer intake wont hurt mpgs,and they are much cheaper than the aluminum tbi intake.Also,a performer should give a boost in low rpm torque.I dont see were some portwork on the exhaust side will hurt anything,it should help with some extra power,and the millage shouldnt suffer much.Im thinking of a compucam.I been doing some research,and they say it really increases bottom end torque,AND mpg.The headers are coming pretty soon,i hope,along with a throttle body spacer,and a computer chip.
Offline Skunksmash
« Reply #16 on: September 16, 2008, 03:41:59 am »
Ive read some throttle body spacers are good for some extra mpg,1 mpg is better than nothin.
I heave heard the same thing. Can someone here explain to me why a throttle body spacer helps to increase gas mileage?
« Reply #17 on: September 16, 2008, 10:59:40 am »
They raise the TBI up helping the distribution of the fuel to the cylinders.  TBI spacers are good from adding some mpg and some power.
http://www.cfm-tech.com has been popular lately with the ones they have.
Offline Skunksmash
« Reply #18 on: September 16, 2008, 07:45:55 pm »
If you get one thats 1 and a half inches thick, or maybe even 2 inches thick, do you run into any clearance problems?
« Reply #19 on: September 17, 2008, 03:41:02 pm »
1" would be safe I am sure, I would measure for anything larger than that.  Move it up WILL require an adapter to lengthen the supply/Return lines, they have those also.
Offline Skunksmash
« Reply #20 on: September 17, 2008, 06:19:11 pm »
How exactly would you measure? Can't exactly do it with the hood closed.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #21 on: September 17, 2008, 08:41:15 pm »
stack some eggs on the air filter housing---stack em up 2 inches high and slam the hood.  See if they are scrambled afterwards.
Really, put a small box or something on the cleaner and close the hood.
Do you have a digital camera with a timer?  set it on 10 seconds inside the engine compartment and close the hood.
« Reply #22 on: September 17, 2008, 10:35:45 pm »
Playdough, clay...
Offline comp
  • 76-77-78
« Reply #23 on: September 20, 2008, 01:19:47 pm »
