Author Topic: individual gauge installation questions  (Read 8596 times)
Offline got2haul
« on: August 22, 2008, 09:16:41 am »
(I did a search to see if I could find info on this but was unsuccessful, so forgive me if this has been discussed in an earlier thread)
My truck was built with warning lights rather than gauges.
1.  Is it possible to replace the warning lights with individual gauges?
2.  If the lights are replaced with GM gauges, is the printed circuit sheet required to make them work, or can the gauges be wired separately?
3.  Could I remove the warning lights and replace them with individual aftermarket gauges, and somehow mount them in the factory locations (and still use the factory-style bezel)?
4.  Anyone already done this?
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Offline DnStClr
Re: individual gauge installation questions
« Reply #1 on: August 22, 2008, 09:49:54 am »
It can be done. Do a search for swapping gauges to refresh an earlier post when you were a new guy. ;D
Don
87 Chevy Silverado
« Reply #2 on: August 22, 2008, 10:41:11 am »
1) Yes, but it is best if you replace the complete cluster assembly from a comparable year truck.  You cannot put gauges where the warning lights were
2) See above, you cannot put gauges where warning lights were.  The printed circuit is also specific to the cluster configuration
3) Yes = http://www.73-87.com/7387garage/interior/gauges_recessed.htm
4) see item 3...  bigblock73 did his this way: http://www.73-87.com/7387garage/interior/gauge_surface.htm   There are a few people on here that have done this also.
Offline got2haul
« Reply #3 on: August 22, 2008, 01:58:48 pm »
Thanks.  Both write-ups are good info.  DnStClr -- here I thought I was making progress and its become painfully obvious that my truck to-do list is moving along so slowly!  Apparently I keep adding items to the list that become higher priorities.  I do believe though, that even when the to-do list is complete, the truck will never be finished!
« Reply #4 on: August 22, 2008, 02:45:54 pm »
Nope, it will NEVER be finished...
Offline bigkountry
« Reply #5 on: August 23, 2008, 11:13:19 am »
There will always be something to replace/modify...thats the fun part  ;D
