Author Topic: light above the rear window inside the cab won't turn off?  (Read 7519 times)
Offline 73c10Shorty
  • 73 Chevy Shortbed
« on: August 26, 2008, 10:40:33 pm »
Ok, so I'm not sure what's going on here. I guess the first question is how do you turn on the dome light (not sure what it's called but it's the light above the rear window in the cab)? I noticed it was on tonight and the only way I can get it to turn off is by turning my headlight switch knob all the way to the left which turns on the floor light. So at that point the dome light is off but the floor light is on. If I turn the headlight switch knob back to the right the floor light turns off but then the dome light is on again. What the heck?? ???
« Last Edit: August 27, 2008, 10:58:19 am by 73c10Shorty »
1973 C10 Shortbed, 350/350
Offline hotrod24
Re: light above the rear window inside the cab won't turn off?
« Reply #1 on: August 27, 2008, 01:52:34 pm »
mine did the same thing check your door jamb switches and when you close the door the dome light should go off so it might be the switches
1978 pontiac grand prix...
Offline 06gsxrman1000
« Reply #2 on: August 27, 2008, 02:50:26 pm »
i had this mprob i ended up temp. putting the two wires together so that it was like the switch was working and then ordered two new ones
Three may keep a secret, if two of them are dead.
-ben franklin
Offline 73c10Shorty
  • 73 Chevy Shortbed
« Reply #3 on: August 27, 2008, 03:57:40 pm »
That was it. This forum and its members impress me more and more every day. Can't wait until I can actually contribute something. Thanks again!
Offline DnStClr
« Reply #4 on: August 27, 2008, 04:58:22 pm »
Was it a bad ground or  door switch?
Don
87 Chevy Silverado
Offline 73c10Shorty
  • 73 Chevy Shortbed
« Reply #5 on: August 27, 2008, 05:04:58 pm »
The switch on the drivers side is shot. I'm ordering two new ones.
