Author Topic: metal dash removel  (Read 31420 times)
Offline Redneckchevy
    • Photo Bucket
Re: metal dash removel
« Reply #15 on: September 08, 2008, 07:42:31 pm »
So you going to have it media blasted?....Did a great job of removing the old dash....Looks like its going to be fun to remove all that rust
Offline hotrod24
« Reply #16 on: September 08, 2008, 08:12:34 pm »
yea i am going to get it blasted and thanks for compliment :)
1978 pontiac grand prix...
Offline hotrod24
« Reply #17 on: September 09, 2008, 04:26:40 pm »
well i got my doors off and now it is time to sand everything and primer everything man i hope i get a shop they say it is going to be a bad winter but i had to take all of it off because of rust.
Offline ccz145a
« Reply #18 on: September 09, 2008, 04:34:36 pm »
use epoxy primer, it is impermable to water. regular primer has talc in it and soaks up water
Offline hotrod24
« Reply #19 on: September 09, 2008, 09:41:45 pm »
is there anything that i can use to get that stuff off my fire wall it is like a mix of insulation and goop
Offline ccz145a
« Reply #20 on: September 10, 2008, 07:38:24 am »
There is no easy way that I've heard of.
Heat gun and scraper...wire wheel...wax/grease remover.
Anyone else?
Re: metal dash removal
« Reply #21 on: September 10, 2008, 01:12:21 pm »
Paint stripper?  I used some stuff a long time ago that made it real gooey and you could wipe it off, but it took several applications.  I don't remember what it was...
Offline hotrod24
« Reply #22 on: September 10, 2008, 05:54:17 pm »
ok i was cleaning up my fire wall and i thought i would go ahead and unbolt my wiring harness i taged every thing so i would know where everything went and i am going to get a new harness and i might need some of this harness so what is the best way to do this can i take it a part or should i cut it and split it up?
and another thing how do you get the cable off the back of the of the parking brake?
« Last Edit: September 11, 2008, 06:34:30 pm by hotrod24 »
Offline hotrod24
« Reply #23 on: September 11, 2008, 06:39:04 pm »
so should i keep it for later or spilit the harness up?
« Reply #24 on: September 12, 2008, 12:23:01 pm »
I would keep it for later, you never know what you might need.  after it is running they you could chunk it.
Offline hotrod24
« Reply #25 on: September 12, 2008, 12:39:05 pm »
ok sound good thanks
« Last Edit: September 13, 2008, 09:23:57 pm by hotrod24 »
Offline 80stepsideguy
« Reply #26 on: November 08, 2008, 11:59:42 pm »
Still need a metal dash for your truck? I just  JUST pulled off mine from my 85 last night and its sitting on the floor right now and i`m gonna be removing the spot welds from the 76 dash i got from a member here.PM me if your wanting it or IM me .
thanks
pat
« Last Edit: November 09, 2008, 11:08:49 am by 80stepsideguy »
1998 Chevy 1500 S/B 2wd
Offline bill.ohlhausen.7
« Reply #27 on: November 22, 2013, 11:55:06 pm »
@hotrod what did you use to drill out the spot welds?
Offline DnStClr
« Reply #28 on: November 27, 2013, 06:08:50 pm »
I see a die grinder with a cutting wheel on it in one of the pics...
Don
87 Chevy Silverado
