Author Topic: casting numbers  (Read 5668 times)
Offline 2502
casting numbers
« on: August 30, 2008, 12:13:26 pm »
i've been on google a good bit of the morning and can't seem to find what year application my motor is supposed to be. it'd help since i was replacing gaskets, all i could find was id charts for the casting numbers but they're not listing the year.
it's a 10066036...
any ideas?
Offline team39763
Re: casting numbers
« Reply #1 on: August 30, 2008, 01:08:22 pm »
I believe Mortec.com has the casting #'s you're looking for.  That's where I go to look up casting #'s.
Offline 2502
Re: casting numbers
« Reply #2 on: August 30, 2008, 01:33:07 pm »
i did look there, but it didn't list the year for it. unless i'm supposed to assume it's for the 86 above that they listed for the other block ahead of mine.
this is how it reads:
10054727...350...86-up...2 or 4...one piece rear seal, some "Made in Canada"
10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear
                             seal, "Hecho en Mexico"
10066038...350.....92....4...Goodwrench crate motor, 2-piece rear
Offline HAULIN IT
Re: casting numbers
« Reply #3 on: August 30, 2008, 02:16:43 pm »
It would appear that is an "over the counter" GM replacement engine. Not the original one in any GM vehicle. Lorne
Re: casting numbers
« Reply #4 on: August 31, 2008, 02:23:49 pm »
It is an over the counter replacement as Lorne pointed out.  Unless it is a 1 piece rear seal, any pre-86 SBC rebuild kit will work.
Offline 2502
Re: casting numbers
« Reply #5 on: August 31, 2008, 02:39:35 pm »
i tried gaskets so far for a 80 up til we got to the oil pan gasket, then the gasket from the 77 was the one that seemed to fit. but when we pulled the spark plugs i think that said for a 79. i just wanna save the gas and the headaches of running back and forth to auto zone and not being able to finishs omething one night cuase it's too late and it's closed....
