Author Topic: 14 Bolt Full Floater ???  (Read 25867 times)
Offline wirenut
Re: 14 Bolt Full Floater ???
« Reply #15 on: September 10, 2008, 05:02:38 pm »
do you remember if the springs were ouitside or inside the frame..just a thought
« Reply #16 on: September 10, 2008, 10:47:24 pm »
They were outside the frame just like every other Chevy I have tore apart. Almost 3" wouldn't be enough to clear inside the frame even if it was possible.
Offline cracker0169
    • Myspace
« Reply #17 on: September 11, 2008, 05:26:08 pm »
ya got me!  :-\
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
Offline wirenut
« Reply #18 on: September 13, 2008, 07:42:13 pm »
whats your measurements  to center of perches, i'll measure mine .. for comparison if you want..
« Reply #19 on: September 13, 2008, 11:45:02 pm »
Werern't the perches wider on the one tons than the 3/4 ton and half ton models? I can measure my one ton Monday if you want
« Reply #20 on: September 14, 2008, 01:42:32 am »
I am not sure. A buddy of mine says he swapped in a 1 ton 14 bolt rear and don't have to move them. I think he got a 3/4 ton unit and paired it with a Dana 60 front. Doesn't matter its in now, I cave maned and welded it too! Gotta put a caliper on it in the AM and its ready for the bog. Couple little things like put the grill back in ( zip ties are your friends ), etc.
« Reply #21 on: September 14, 2008, 02:22:10 pm »
What did you have to do to make it work?
Offline 86 chevy silverado
« Reply #22 on: September 14, 2008, 03:31:11 pm »
I just read this thread for the first time and went outside to check my one ton (14ff) to my 3/4 ton (both '86) and the one ton is 2 1/2" narrower than the 3/4 ton rear.
« Reply #23 on: September 14, 2008, 03:56:04 pm »
The whole axle is or the perch center to center?
« Reply #24 on: September 14, 2008, 04:05:48 pm »
Leaf spring perch center to center, the axle width is the same.
« Reply #25 on: September 14, 2008, 04:09:27 pm »
Interesting. We should make a sticky thread on the differences between all of the axles. We can take measurements and such and post details as this can help with some of the interchangability issues between yokes and mounts etc.
« Reply #26 on: September 14, 2008, 04:36:59 pm »
Another difference I just ran into is that I have an open differential on my 86 K2500 14blt and was hoping I could swap it with the 14blt limited slip rear out of my 81 C20 thinking the rear should be the same but the brake drums are wider on the 86 so I opted not to do the swap.
« Reply #27 on: September 14, 2008, 06:53:25 pm »
why did that stop you from doing the swap?
« Reply #28 on: September 14, 2008, 07:28:29 pm »
I went round and round with the idea, I basically decided I wouldn't do the swap if I had to go to smaller brakes (thats backwards to me) and they could not be swapped over to the other rear because the axle tubes are also different lengths.
« Reply #29 on: September 15, 2008, 12:45:28 am »
The shock are mounted inside the frame on the one ton pick up I have and the one the rear end came from too. Where as the 1/2, & 3/4 tons are on e the outside of the frame.
 I chopped the old ones off, then I cut two pieces of 2"x2"x1/4" wall square stock 5" long, cut a radius in one side to match the axle housing, drilled a hole for the center bolt in the top, & welded them on
