Author Topic: VIN Plates and paint  (Read 12309 times)
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« on: September 04, 2008, 10:54:31 am »
What did you guys do with the vin plate on the door jamb of the drivers door and the Tire info sticker on the door itself when you painted your truck?  I'm thinking just mask them off.  What do you think, drill out the rivets on the plate and peel off the door sticker? I'd like to not lose the sticker, but I can re-rivet the plate back on once I find the right size rivets.
Offline JJSZABO
Re: VIN Plates and paint
« Reply #1 on: September 04, 2008, 11:28:15 am »
The doors on mine are from a donor vehicle - I don't have any stickers on them anymore.  I removed them.
If I wanted to save a sticker while painting, I just taped over them, then painted.
Jeff
86 Chevy C-10
350, TH400
Offline ccz145a
« Reply #2 on: September 04, 2008, 02:58:14 pm »
Good luck finding original style rivets. For obvious reasons, they are not legaly marketed. Many bodyshops just pop in regular rivets when that area is repaired with no problems. But if you can, just tape it off and paint, it will eliminate any questions in the future.
  • Z62 ON-ROAD
« Reply #3 on: September 04, 2008, 03:16:23 pm »
thats a good point ccz145a.  I did notice the rivets look kinda flower shaped rather than round...  I'll just mask em off.
« Reply #4 on: September 04, 2008, 08:23:13 pm »
I would mask them off. If you need to take them off just use regular rivets to replace. Or I have used a very small file to cut the heads of the rivets to look like the originals. thats what I did when I put the vin tag from my 86 cab onto my 83 cab on my 86 frame. As far as installing new or used doors, and saving the stickers. I take an air chisel, chop out the metal of the old door, and toss it in the glove box.
Offline Bowtie4004x4
« Reply #5 on: September 04, 2008, 08:27:50 pm »
 lol....hehe... I thought of the file trick, but thought maybe I should'nt post that in here ..lol
I'm spending my children's inheritance on my Trucks.
'78 3/4 fleetside 4x4 4oo/400 3:73gears (frame off rebuild)
'80 3/4 fleetside 4x4 305/400 4:10gears (if I took the body off the frame it would fall totally apart...lol )
« Reply #6 on: September 04, 2008, 10:44:43 pm »
My concerned look, huh, same as in my avatar!
« Reply #7 on: September 05, 2008, 09:40:21 am »
DISCLAIMER:
This is for information only, 73-87chevytrucks.com, Chris Lucas Enterprises or anyone associated with this company or website do not condone or encourage any tampering with VIN plates and will not be held liable by the information and what those viewing this site do with said information. - Chris Lucas
They are called rosette rivets.  They are available as there are times when parts of the Truck/Car  (73-87's with the VIN in the door ) can be damaged.
There is a standard that body shops must follow for any VIN alterations, check with them on any specific procedures.  Some newer cars have to be inspected before it is removed and have to be present when it is replaced...
http://restorivets.com/index.php?_a=viewCat&catId=2
http://www.trimtags.com/ ( I understand you have to ASK for JUST VIN rivets.)
Offline frogman68
« Reply #8 on: September 05, 2008, 10:01:25 am »
Wow those rivets are pricey :)
I like Blazin's idea :)
Offline JJSZABO
« Reply #9 on: September 05, 2008, 10:09:18 am »
 :o
YOW - must be made of gold.
Jeff
86 Chevy C-10
350, TH400
  • Z62 ON-ROAD
« Reply #10 on: September 05, 2008, 05:42:45 pm »
Thanks for the info captkaos.  At $105 for 4 rivets :o, I'll just put some tape over my plate for free. ;D
« Reply #11 on: September 06, 2008, 12:27:41 am »
WHoa, bend over, $105. They are out of their minds! ::)
