Author Topic: quadrajet question  (Read 4741 times)
Offline ole blue
  • New Users
quadrajet question
« on: September 04, 2008, 06:05:49 pm »
I just bought a 79 seirra grande with a 350 and quadrajet, truck runs great but gets horrible mileage. I cleaned the air filter(k&n) and while it was off I noticed that a larger vacuum outlet(?) at the front of the carb near the top was not connected to anything. I could not find a unconnected vacuum hose anywhere. My question is is supposed to capped off or conected somewhere else.
Thanks
Rod
Online zieg85
Re: quadrajet question
« Reply #1 on: September 04, 2008, 06:32:16 pm »
Pretty sure you are looking at the vent tube that would go to the charcoal canister.
Offline JJSZABO
« Reply #2 on: September 04, 2008, 07:23:13 pm »
On mine it goes to the PCV valve and the charcoal cannister
Jeff
86 Chevy C-10
350, TH400
Offline ole blue
  • New Users
« Reply #3 on: September 04, 2008, 08:42:46 pm »
So it looks like is should go to the pcv valve.   Thanks im gonna check it out... Will it hurt to not go to anything?
Rod
Offline jefferias
« Reply #4 on: September 04, 2008, 09:25:58 pm »
i have a q-jet as well.   Id say defn hook up your pcv valve should make it run better id think. and if you dont want to hook it up, which i dont reccomend, at leawst plug it off cause your carb will be sucking in un filtered air which is not good. and also put a breather cap where your pcv should be. but again i would just hook it up. hope it helps
Offline JJSZABO
« Reply #5 on: September 05, 2008, 07:20:27 am »
I would recommend hooking up the PVC valve also.  At a minimum, you need to do as jefferias suggests if you don't use the PVC valve.
Jeff
86 Chevy C-10
350, TH400
« Reply #6 on: September 05, 2008, 08:51:52 am »
You NEED a PCV valve or it will find any weak spot and blow all the oil out of it.  If you are running a breather on the valve cover, you should be ok.
