Author Topic: sm465 shifter removal  (Read 7147 times)
Offline cptn60
« on: September 08, 2008, 01:48:08 pm »
Any ideas on how to remove the shift lever? 1985 c20 6.2j with non removable trans tunnel. If possible, I'd rather not try to wiggle the fairly heavy unit out with the stick still attached.
86 c10 shorty
Offline frogman68
Re: sm465 shifter removal
« Reply #1 on: September 08, 2008, 02:06:32 pm »
look at the tower you should see how it locks.
Mine I had to push down and turn it with a pipe wrench it was stuck
Offline cracker0169
    • Myspace
« Reply #2 on: September 08, 2008, 05:07:55 pm »
The cap pushes down and turns counter clockwise.  You shouldnt have to turn it but about 1/4 turn and it should pop up.
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
Offline cptn60
« Reply #3 on: September 08, 2008, 11:23:13 pm »
Thanks guys, worked great! Trans is still pretty heavy  though.  ;D At least it came out without trying too hard.
86 c10 shorty
Offline frogman68
« Reply #4 on: September 09, 2008, 02:21:43 am »
Great
Just remember if you have to remove it , it weighs 185lbs
