Author Topic: Electric fan install --84 GMC  (Read 51744 times)
Offline 85MudMonster
Re: Electric fan install --84 GMC
« Reply #15 on: January 05, 2009, 07:55:32 pm »
I did this. I've got one 16" and one 14" and have upgraded to a 94 Amp alternator off a Chevy Van, cause the stock 78 Amp one was not enough at night to keep the haedlights from dimming with the fan on, which is just wired into an on/off switch (which has been forgotten to be switched on when driving a couple times, but never overheated it yet).
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
« Reply #16 on: January 06, 2009, 05:03:09 am »
Wire up a thermostatic control. You can get one for around $30 bucks at autozone. It's adjustable and comes with the relay and circuit protection.
Offline houston81er
« Reply #17 on: January 27, 2014, 01:40:22 am »
What brackets did you use to hold the radiator in place? I have an 81 Chevy and the stock ones don't look like that? -Thanks
-It's not where you're from it's where you're at!
« Reply #18 on: January 27, 2014, 05:46:09 pm »
If you are referring to the original post in this thread from 2008 he may not respond but those are the stock 6 cylinder radiator mounts for 81 up rad support
