Author Topic: Towing with a lowered truck  (Read 16817 times)
Offline cmexlr8
« on: September 17, 2008, 08:38:34 am »
I need some opinions/help with what I need to do to my truck to help with towing. I will be towing a 3500 lb car and occasionally a boat. The truck is lowered(see pics here - http://forum.73-87chevytrucks.com/smforum/index.php?topic=9415.0). I figure that I will need a under the bumper hitch, possibly helper springs or air bag helpers. I have a brake controller that I am going to put on. I am not worried about the transmission or motor, I just need guidance on issues with towing with a lowered truck.
Re: Towing with a lowered truck
« Reply #1 on: September 17, 2008, 11:16:06 am »
How is it lowered? how much tongue weight will it have?
Helper airbags should work fine in leveling the load.
Offline cmexlr8
« Reply #2 on: September 17, 2008, 12:36:17 pm »
It is lowered in the back with shackle relocation. Not sure on the tonque weight -  I will be pulling a 3500 pound Chevelle with an 18 ft open trailer.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: September 17, 2008, 01:02:36 pm »
Obvioulsly your suspension no longer has the stock "play" for up and down movement. Towing a load requires a certain amount of up and down movement.  However, by beefing up your suspension with bags or stiff leafs will be beneficial---you'll probably have to anyway to reduce sag under the weight.
Something to look into would be a hitch distributor.  What it does is help distribute the rear weight from the tongue to the front wheels of the tow vehicle.   I have one on my 30' camper trailer and it works wonders.   As soon as I tighten up the distribution arms with the chains, when I turn the crank to put all weight on the vehicle, the rear  doesn't sag any additional amount.  They are amazing.
« Reply #4 on: September 17, 2008, 03:38:36 pm »
If it has a shackle reversal ONLY it and is dropped that low, you are going to be hitting the framerails with a trailer.
Offline Novadiecast
« Reply #5 on: September 17, 2008, 07:15:16 pm »
I think it can be done!
1985 Crew Cab dually project soon to be SRW Short Bed
Offline cmexlr8
« Reply #6 on: September 17, 2008, 08:25:14 pm »
I bought this truck recently, so I am still figuring things out. It has lowering shackles and hangers in the rear and front lower control arms with recessed spring buckets. It is really to low for my liking. I was looking at the front and in addition to the recessed buckets, the springs look collapsed. My guess is someone heated them with a torch to get them to sag. There is only about 1" :o of travel and I can clearly see where the control arm is contacting the subframe. I also think someone has removed a leaf in the rear to make the truck sit even lower. I need to figure out my options to fix it right so it still has a good stance, but it is safe and will have a chance at towing.
« Reply #7 on: September 17, 2008, 10:44:47 pm »
Shackles AND hangers are more like it.  You would still need helper bags.
If the front springs were heated, I would replace them...
Offline cmexlr8
« Reply #8 on: September 18, 2008, 05:22:36 am »
Since it has the lowering style lower control arms, should I buy stock height springs or lowering springs? I want the end result to be lowered but a little higher than now. I suppose I need to figure out how much the LCA's I have are meant to lower and go from there.
Offline JJSZABO
« Reply #9 on: September 18, 2008, 07:47:34 am »
 :o :o
That does NOT look safe
Jeff
86 Chevy C-10
350, TH400
Offline cmexlr8
« Reply #10 on: September 18, 2008, 09:01:31 am »
 :o :o
my guess is that that truck is on bags and it is sitting at 'Parade Rest'. I am pretty sure it runs down the road with enough air in the bags to get a suitable ride height.
Offline JJSZABO
« Reply #11 on: September 18, 2008, 09:31:36 am »
I would hope so  ;D
Jeff
86 Chevy C-10
350, TH400
« Reply #12 on: September 18, 2008, 09:33:29 am »
Lowered control arms generally came in at about 2 or 2.5" drops.  It would help to know which yours are or who made them.
How much higher do you want it from where it is now?  Now it is roughly a 4/6 drop.   (Unless the front is sitting/riding on the bumpstops.
I don't think you want to go with stock springs, but maybe 1 or 1.5" drop springs.
On the rear, regardless of how it is lowered, you HAVE to C-notch the frame, or the axle will be banding on it with a load.  If you added a helper bag setup you could use it to support some of the weight also
I 99% sure the dually is on bags.  There is a few in a thread on here with some.  One pulling a load down the road draggin.
Offline comp
  • 76-77-78
« Reply #13 on: September 20, 2008, 01:18:13 pm »
 i'd bet on bags
