Author Topic: 3/4 ton axles, will they fit 15 inch wheels?  (Read 5579 times)
Offline trickedout420
« on: September 22, 2008, 02:24:36 pm »
im looking to do things on the cheap here..i picked up a set of 3/4 ton axles, 10 bolt front (8 lug hub) and 14b FF rear (planning on disc brake conversion) im wondering if i can order a set of 15 inch wheels so that way i dont have to settle with a pair of 35 inch bfgs for the 16.5 inch wheels..im running 38x14.50r15's now and they still had alot of tread so i was going to order a set of wheels and swap the tires over will the 15s fit on those axles without any mods?
Re: 3/4 ton axles, will they fit 15 inch wheels?
« Reply #1 on: September 22, 2008, 02:55:54 pm »
You might have to grind the calipers on the front (or get a different backspacing, but they should clean.
