Author Topic: spring hangers  (Read 67708 times)
Offline hotrod24
Re: spring hangers
« Reply #45 on: October 13, 2008, 09:43:49 pm »
i have called every dealer ship but know one has them
1978 pontiac grand prix...
Re: spring hangers
« Reply #46 on: October 13, 2008, 09:52:35 pm »
Did you ask if they could order them?
Offline hotrod24
Re: spring hangers
« Reply #47 on: October 13, 2008, 10:05:17 pm »
yea they said that there computer only when back to 82 but if i had a part number they could maybe get them
Offline Dirtydog
Re: spring hangers
« Reply #48 on: October 13, 2008, 10:09:10 pm »
Didn't the part number I gave you work?
-Josh
Re: spring hangers
« Reply #49 on: October 13, 2008, 10:24:35 pm »
Dirtydog,
Post the number and I will get my contact to look it up.
Offline hotrod24
Re: spring hangers
« Reply #50 on: October 14, 2008, 12:26:37 pm »
well i called them and gave them the part number and yes they can order them
thanks
Offline hotrod24
Re: spring hangers
« Reply #51 on: October 14, 2008, 06:08:33 pm »
well here it is i got one of them off and boy was it a pain
Offline Donut
Re: spring hangers
« Reply #52 on: October 14, 2008, 07:49:40 pm »
How bad is that backing plate?
Looking good, the rest "should"  go easier now that the first one is off.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline hotrod24
Re: spring hangers
« Reply #53 on: October 14, 2008, 08:35:23 pm »
well the back plate is just like the hanger it has a hole in the middle of it now what is the best way to grind the back plates rivets?
Offline Donut
Re: spring hangers
« Reply #54 on: October 14, 2008, 08:47:25 pm »
"smoke wrench"...  They're not that bad to grind off.  Is there a bolt that holds the cross member in the way?  (I don't know, it looked like a rotted out sleeve on mine.  Top flange to bottom flange on the frame, above that bracket)
350/tbh350/np205
Offline hotrod24
Re: spring hangers
« Reply #55 on: October 14, 2008, 09:31:25 pm »
whats a smoke wrench? yes i can get in there to the rivets pretty easy i just did not want to lay on my back to do it.
Offline Donut
Re: spring hangers
« Reply #56 on: October 15, 2008, 06:30:34 am »
"smoke wrench"= cutting torch.
I was able to sit on the ground between the frame rails and get to the rivets.  Saves working overhead.
350/tbh350/np205
Offline ngarman123
Re: spring hangers
« Reply #57 on: October 15, 2008, 06:33:34 am »
i wish i would of seen this post yesterday! i was wrestling with my rear springs the whole night! i guess everyone is having the same problem that i had! those front bolts were a pain in my a**! finally got them out with some dirty words and a sore back today but i am on the fence about my spring hangers. they are not rusted through and look ok but there is some rust on the back side where the nutt was in that pocket. i think i am going to clean them up the best i can and take a better look. is there any where i should be looking for like prone areas to be bad? i will try and post pics in the next couple of days.
Offline hotrod24
Re: spring hangers
« Reply #58 on: October 15, 2008, 11:35:44 am »
you know i went through the same thing but i said what the heck when i get a shop i am going to tear it down to the frame and start over so i am going to get the frame powdercoated and all the hangers.
Offline Donut
Re: spring hangers
« Reply #59 on: October 15, 2008, 05:28:46 pm »
ngarman123 ,
Mine were rotted through in the same places that hotrod 24s pics showed above.  Basically anyplace sand, roadsalt or any other crud can sit.
350/tbh350/np205
