Author Topic: spring hangers  (Read 67665 times)
Offline 77 step
Re: spring hangers
« Reply #30 on: September 30, 2008, 10:17:14 pm »
would a torque wrench get the bolts off?
I would not use a torque wrench to remove nuts / bolts.  A torque wrench is a precision instrument for tightening bolts / nuts to an exact tightness.  Use a breaker bar, or an impact wrench... or a cutoff wheel on a grinder, as the bolts are not likely in good enough shape to be used again. (at least around here)
My bolts had to be pressed out of the leaf spring eyes, after they were cut.  You will probably notice a lot of rust or wear where the bolts go through the spring eye bushings once you get them apart.
Sean
Sean
1977 K-10 stepside under slow reconstruction.
Offline hotrod24
Re: spring hangers
« Reply #31 on: September 30, 2008, 10:51:56 pm »
ok thank you
Sean
« Last Edit: September 30, 2008, 11:32:08 pm by hotrod24 »
1978 pontiac grand prix...
Offline Dirtydog
Re: spring hangers
« Reply #32 on: October 01, 2008, 03:46:40 pm »
Ok found them at my local Chevy Dealer. He ordered them straight from GM.
-Josh
Offline hotrod24
Re: spring hangers
« Reply #33 on: October 01, 2008, 04:00:30 pm »
well i just called and they said that there computer does not go back that fear but he said that if i had a part number he could run it did you get a part number
« Last Edit: October 01, 2008, 04:36:22 pm by hotrod24 »
Offline Donut
Re: spring hangers
« Reply #34 on: October 01, 2008, 04:33:31 pm »
Check a couple of different GM dealerships, (and guys working the parts counter).  One guy on the computer was able to order my spring mounts but another time a different guy told me that my transfer case didn't go behind my transmission that year (1973) and couldn't get my seals and gaskets.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline hotrod24
Re: spring hangers
« Reply #35 on: October 01, 2008, 04:36:45 pm »
ok thanks
Offline hotrod24
Re: spring hangers
« Reply #36 on: October 01, 2008, 06:19:48 pm »
do i need these they are weld to my frame for something
« Last Edit: October 01, 2008, 06:21:49 pm by hotrod24 »
Offline ccz145a
Re: spring hangers
« Reply #37 on: October 01, 2008, 06:25:03 pm »
Nope, old exaust hangers.
Offline hotrod24
Re: spring hangers
« Reply #38 on: October 07, 2008, 07:37:37 pm »
what is the best way to get a bolt out of a leaf spring? i cut the bolt on both sides now it is stuck in there i tryed a hammer but did not work
« Last Edit: October 07, 2008, 09:05:27 pm by hotrod24 »
Offline Dirtydog
Re: spring hangers
« Reply #39 on: October 07, 2008, 09:36:07 pm »
Hmm should have let the head on the bolt, that could be a problem now, I sprayed it with WD40 and pulled and it came right out. Jack the frame up so that there is no pressure on the leaf and then get a piece of metal that is bent at a 45 and put it at the back of the bracket and try and knock it out towards you.
-Josh
Offline hotrod24
Re: spring hangers
« Reply #40 on: October 07, 2008, 10:37:24 pm »
yea i wish i would have left the head on it lol i will try that.
thank you
Re: spring hangers
« Reply #41 on: October 08, 2008, 08:10:01 am »
Use an air hammer and lots of penetrating oil. Otherwise get out the torch.
Offline 77 step
Re: spring hangers
« Reply #42 on: October 09, 2008, 12:57:28 pm »
Mine got the torch.  I was replacing bushings in the spring eyes, and the fire helped get the old ones out.  Stinky, though!
Sean
Offline hotrod24
Re: spring hangers
« Reply #43 on: October 11, 2008, 03:05:42 pm »
well i hammered and hammered the bolts and they will not come out i got a air hammer so i am going to try that.
Offline hotrod24
Re: spring hangers
« Reply #44 on: October 13, 2008, 08:15:50 pm »
well the air hammer did not work now what
