Engine/Drivetrain
5 speed swap 83 k10
Topic: 5 speed swap 83 k10 (Read 6428 times)
scottwv
New Users
5 speed swap 83 k10
September 26, 2008, 10:31:56 am »
I have an 83 k10 w/ 4speed and 208 transfer case. Is it possible to use a 5 speed from a 88-95 in it. Has anyone done or tried this conversion? Thanks for any help or advise.
cracker0169
Re: 5 speed swap 83 k10
September 28, 2008, 10:05:56 pm »
I have considered the swap myself. Depending on the transmission (3550 or 4500) your issue will be the adapter that bolts to the transfer case. I like the idea of a 5 speed but that is also one more thing to break on the trail or in the mud. One thing I do not like about the 3550 (not sure of 4500) is that the bellhousing is part of the trans. Major pain to swap a clutch out. If you decided to do the swap, you would have to use the clutch pedal assembly off of a 85-87 since they used a hydro throwout bearing. If it were me, Id ditch the 208 and find a 205 and be good to go!
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
September 29, 2008, 01:56:11 pm »
It would be easier (in my opinion) to go to the NV4500. The NV3550 in the 1/2T trucks aren't half as strong as the SM465 that you currently have. This is a fairly popular swap.
Engine/Drivetrain
5 speed swap 83 k10
