Author Topic: What 73-80 Fenders do you sell?  (Read 7936 times)
Offline hotrod24
« on: October 02, 2008, 03:06:45 pm »
what kind of fenders do you sell chris
« Last Edit: October 03, 2008, 12:04:34 pm by hotrod24 »
1978 pontiac grand prix...
Re: Damage Repair, 1978 C20
« Reply #1 on: October 02, 2008, 03:19:25 pm »
I sell GoodMark 73-80 fenders.
Offline hotrod24
« Reply #2 on: October 02, 2008, 03:20:51 pm »
ok good thanks chris
Offline Skunksmash
Re: What 73-80 Fenders do you sell?
« Reply #3 on: October 04, 2008, 01:39:45 pm »
Same for 81-87?
Offline 80stepsideguy
« Reply #4 on: October 04, 2008, 01:59:13 pm »
Chris`s fenders fit very well.I bought 2 from him and other then a lil tweaking here and there there a perfect fit. I couldnt be happier with them rather then the POS used ones i had that the guy had them all bondoed  up and had red lead all over the place.I paid 50.00 for the pair and they went to the dump after i looked at them and decided to get a pair from chris.
thanks
pat
p.s. skunksmash, yeah i think  he sells 81-7 goodmark fenders as well.
1998 Chevy 1500 S/B 2wd
« Reply #5 on: October 04, 2008, 02:11:47 pm »
Yes, I sell 81-87 Goodmark fenders also, but they are not "tweaked" like the 73-80 versions are.  They are standard Tr-Pluss versions.  I haven't had a problems with those though.
Offline Skunksmash
« Reply #6 on: October 05, 2008, 03:16:08 pm »
Whats the difference?
« Reply #7 on: October 05, 2008, 08:40:12 pm »
Difference in what?
Offline Skunksmash
« Reply #8 on: October 05, 2008, 11:52:30 pm »
Price, fit, you said they are not "tweaked". Whats that mean? Some aftermarket body parts don't really fit very well.
« Reply #9 on: October 06, 2008, 12:03:10 pm »
Goodmark modified the Tri-pluss stamping of the standard 73-80 fenders to fit better, and last I checked it was exclusively for them.
They didn't modify the 81-87 version, so it it the same as any other Tri-Pluss fender.  I haven't had problems with the 81-87 versions, but several aftermarket 73-80 versions required extensive work to get it remotely close.
« Reply #10 on: October 06, 2008, 01:14:26 pm »
Only modifications i had to make to the fenders i bought from chis where the top edge is curved, your gonna have to trim a pie cut into the inner support so you can bend it in to get it closer to the windshield post and thats really it.Other than that there a great fit, and look good, but on the pass side i`m having a slight problem bolting the top bolt to the firewall.Its not the fender i think its the cab cause it happened to me on the other fenders i had and it fit the same way.The drivers side is a perfect fit, so i gotta reposition the nut under the place where the top bolt goes thru and reweld it and it should be good to go.
thanks
pat
Offline Skunksmash
« Reply #11 on: October 06, 2008, 06:06:13 pm »
And only 90 bucks too. Pretty cool, seeing as how the chevy house is like 200 bucks.
