Author Topic: 85 K10 Heater problem  (Read 9613 times)
Offline idahok1085
« on: October 10, 2008, 12:18:25 am »
Hey guys, New here. I just picked up a 85 K10 and my Heater isent working here is what is going on:
The fan turns on all settings Low-High, sounds stroung ect. The part that moves from Vent/Def/floor/AC ect ect moves I looked behind there and it appers to me that ALL vac. lines are hooked up, none broken that I can see.  It dose blow out the floor all the time dosent matter what setting I have it on. Also if I turn the sel. all the way to OFF on there it turns it OFF. It just wont turn to Vent or Def. Dose anyone have a Vacuum Diagram of under the hood? Also it has a 350 Swap done to it. Aftermarket Holly carb and intake. Also the HEAT is not hot its cold. Im thinking bad T-stat but I will look into that after I figger out why its not blowing out def. and vents. Any help would be a life saver!! Thanks guys!! I hope I get more help on this site than the others haha  ;D
Re: 85 K10 Heater problem
« Reply #1 on: October 10, 2008, 12:21:17 am »
If you aren't getting hot air to the floor are you getting hot water to the heater core?  Are the lines hooked up?  Is this and AC truck or non-AC?
Offline idahok1085
« Reply #2 on: October 10, 2008, 12:34:05 am »
IT has A/C but I dont have the belt on becuase its almost winter here and I need the heat lol. Everything looks hooked up inside the cab......
« Reply #3 on: October 10, 2008, 12:35:33 am »
Are the hoses hooked up to the heater core on the outside of the firewall?
Offline idahok1085
« Reply #4 on: October 10, 2008, 12:39:25 am »
Yes....... Not sure about Vacuum tho.......
Offline justinm
« Reply #5 on: October 11, 2008, 09:53:54 pm »
your not getting vacum from the engine to the heater control. The hose comes out of the firewall near the heater housing. Make sure you hook it to manifold vacum
