Author Topic: kickpanel vent -- common leak area?  (Read 6074 times)
Offline vince311
« on: October 11, 2008, 10:43:28 pm »
I had noticed that water was pooling on both sides of my cab...near the front of the door, on the inside of the floor weatherstripping.
After removing the carpet and then pouring water on the outside of the fender/windshield area.... it became clear that water is dripping from the kickpanel.
After removing the kickpanel, it appears the seal between the kickpanel and the body is completely stiff and flattened.
I assume replacing the seal is a good idea...but is there anything else that can be done to prevent water from entering through this area? Maybe a Silicone bead?
'82 Chevy shortwide, 2wd, 350/350 - Sold
Online Captkaos
Re: kickpanel vent -- common leak area?
« Reply #1 on: October 13, 2008, 11:16:34 am »
If the seal is stiff, I would replace it.  That should fix the problem.
