Interior & Equipment
Door Hinges
Topic: Door Hinges (Read 5649 times)
Thermal Izod
Door Hinges
October 13, 2008, 04:20:25 am »
For door droop, enough to lift at the handle and clunk it up and down, and enough to cause a need to slam them everytime, just to close.....do you typically just need the hinge pin? or both hinge assemblies on each door....?
1982 Shortbed K10 Silverado. 305 ci with a mild cam, full true dual exhaust (Long tube headers, "H" pipe, and Thrush Turbo mufflers. 4x4, and otherwise completely stock. about 153,000 miles.
ont_guy_38
Re: Door Hinges
October 13, 2008, 07:36:05 am »
In all my years I have never seen a hinge having to be replaced cuz of wear although i am sure if left too long you would have too....usually you can just replace the pins and bushings (or oversize bushings) and your good to go
Re: Door Hinges
October 13, 2008, 10:51:55 am »
It would have to be REALLY bad for you to replace the whole hinge.
Last Edit: October 13, 2008, 11:22:08 am by Captkaos
80stepsideguy
Re: Door Hinges
October 13, 2008, 11:15:47 am »
Ever hear of a bottom hinge going bad and not the top one? The drivers bottom hinge was pretty sloppy so since i had the set from the 1st cab i replaced it on this 1 and no more play.
thanks
pat
1998 Chevy 1500 S/B 2wd
Door Hinges
