Author Topic: 700R4 Conversion  (Read 4345 times)
Offline ms4972
700R4 Conversion
« on: October 17, 2008, 12:12:10 am »
How difficult is it o make the changeover to the OD transmission?  Will my factory tranny x-member work?  Will I need a new driveline?
Re: 700R4 Conversion
« Reply #1 on: October 17, 2008, 09:47:38 am »
You need to move the crossmember back and redrill mounting holes for anything Pre 1982, in general.  You will also need to modify the location of the mount on the frame by moving it back to get all the gears.
Offline Dragon
« Reply #2 on: October 18, 2008, 03:45:48 am »
Generally you will need to shorten your driveshaft as well, unless you got the correct length one from the donor truck...
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
« Reply #3 on: October 18, 2008, 10:32:00 pm »
forgot to list that, thanks Dragon.
Offline 86swb
  • Born a Chevy man
« Reply #4 on: December 26, 2008, 09:58:03 pm »
When you go from the 350 and if you now have a 3:08 rear in it you would also be best to change to a 3:73 rear end. I had to do this when I changed to a 700R4 in my truck. You even get better gas mileage with the 3:73. The gears in the 700R4 are different than in the 350. I did not have to shorten my driveshaft. My 350 had the shorter shaft already in it. I also changed the gear indecator over to an overdrive indecator. You can find these on ebay.
'86 swb Siverado
'84 lwb Silverado (low miles)
1931 Model A 2-Door Sedan
  (in family since new)
I just gave the '31 to my Grandson
Offline Leevon
  • "Common Sense Ain't So Common"
« Reply #5 on: December 26, 2008, 10:19:26 pm »
Here are a couple of things to think about also; new dipstick if one doesn't come with the trans, new TV cable, and lock-up stuff.  I put together the lock up with free junk yard parts (vacuum switch and cruise/brake cancel switch).  I swapped from a TH400 and had to lengthen my driveshaft.
1950 3100
1971 Cheyenne
1987 Silverado
2018 Silverado
