Author Topic: Chris - need drivers vent window  (Read 15912 times)
Offline 87GMC2WD
Re: Chris - need drivers vent window
« Reply #15 on: October 24, 2008, 04:24:19 pm »
my doesnt leak water yet so hopefully i could just put in some new rubber and get away with the air leak
Offline JJSZABO
« Reply #16 on: October 24, 2008, 07:59:28 pm »
That's cool - good luck it is the cheaper way :D
Jeff
86 Chevy C-10
350, TH400
Offline JJSZABO
« Reply #17 on: October 27, 2008, 02:39:38 pm »
Received it on Saturday - fast shipping and Great Quality.  I already have it installed.
Thanks again Chris!! ;D
Are you feeling better?
Jeff
86 Chevy C-10
350, TH400
« Reply #18 on: October 27, 2008, 04:00:38 pm »
MUCH better.  Where are the pics of it installed?  Have you driven it yet?
Offline kfoz
  • ALWAYS BUILD WITH BRICK & STONE ! ! !
VENT WINDOW ASSEMBLY
« Reply #19 on: October 27, 2008, 09:59:45 pm »
Is there ANY way we can get these ONE-PIECE window kits for under $500.00??? Also, has anyone ever changed the weatherstripping on those original WINDOW VENTS?? It looks like e real pain!
kfoz
kfoz (kfoz@comcast.net)
'73 C20 4 Speed 2WD
Offline JJSZABO
« Reply #20 on: October 28, 2008, 07:05:17 am »
I havn't driven it yet with the vent window in.  I pulled the door panels to fix the vent window on the drivers side and the door panel on the passenger side to replace the power window motor.  The power window motor went out a week after my son started to drive it.
I'll post pictures - I just got into a hurry.  The vent window fits like a glove though.
Jeff
86 Chevy C-10
350, TH400
Offline JJSZABO
« Reply #21 on: October 28, 2008, 07:56:27 am »
I replaced both of the vent window seals.  They are a pain.  I have a write up on around here somewhere.  I removed the two rivets on the hinge to reinstall the vent window gasket.  After all that work, the passenger side worked but the drivers side didn't.  The drivers side still had bad wind noise and leaked water.
I went ahead and bought a new vent assembly through Captkaos.  I looked at the new one I received and the old one I tried to fix.  I just couldn't get the gasket to "sit" just right in the old vent window.  I used plenty of soapy water to try and coax the gasket into place - but I guess it didn't work.
I have learned to remove these vent windows quickly now :D  It certainly was a good learning experience.
Jeff
86 Chevy C-10
350, TH400
Offline kfoz
« Reply #22 on: October 28, 2008, 05:14:30 pm »
Hey Captkaos! How much for vent window assemblies and do they fit well and look original?
Thanks for your time, kfoz
'73 C20 4 Speed 2WD
« Reply #23 on: October 28, 2008, 05:39:59 pm »
I moved this to the relevant posts.  Yes I can get them, the fit just like factory and look just like factory because they are GM pieces.  They are $245 + shipping.
Read above for more info.
Offline ccz145a
« Reply #24 on: October 29, 2008, 08:16:50 am »
I can tell you they are wonderful, I bought one a few years ago and just put it in last month.
