Author Topic: Chris - need drivers vent window  (Read 15901 times)
Offline JJSZABO
« on: October 20, 2008, 08:34:30 am »
Chris - do you sell new vent windows?
I replaced the rubber around the vent windows, but the drivers side didn't work.  I have alot of wind noise and water leaking.  The passenger side worked.  I want to completely replace the drivers side vent assembly with a new assembly.
Thanks,
Jeff
Jeff
86 Chevy C-10
350, TH400
Re: Chris - need drivers vent window
« Reply #1 on: October 20, 2008, 10:28:10 am »
Yes I can get them.  Takes about 7 days for me to get it though.  Want me to order one?
Offline JJSZABO
« Reply #2 on: October 20, 2008, 10:53:05 am »
How much?  I want to make sure I have the funds?
Jeff
86 Chevy C-10
350, TH400
« Reply #3 on: October 20, 2008, 12:19:52 pm »
The last one was about 189 or so.
Offline JJSZABO
« Reply #4 on: October 20, 2008, 12:27:51 pm »
Order me one Chris.  I need the drivers side (tinted window).  How do you want me to do the transaction?
Jeff
86 Chevy C-10
350, TH400
Offline silvrbreez
« Reply #5 on: October 20, 2008, 04:47:18 pm »
$189 is a good deal.
« Last Edit: October 20, 2008, 07:57:44 pm by Captkaos »
« Reply #6 on: October 20, 2008, 07:59:01 pm »
I had to go to the doctor this afternoon so I will try and call you about the vent, or send me an email.  Don't worry about payment until I get it in my hand.
Offline JJSZABO
« Reply #7 on: October 21, 2008, 07:13:27 am »
Chris, sent you a PM.
Jeff
86 Chevy C-10
350, TH400
« Reply #8 on: October 21, 2008, 10:16:31 am »
ok, they went up.  They are $245 now.  Stupid inflation.
« Last Edit: October 23, 2008, 11:28:50 am by Captkaos »
Offline JJSZABO
« Reply #9 on: October 23, 2008, 08:25:00 am »
Chris - sent you another PM.  Thanks
Jeff
86 Chevy C-10
350, TH400
Offline JJSZABO
« Reply #10 on: October 23, 2008, 11:10:02 am »
Chris, sent payment and PM - Thanks ;D
Jeff
86 Chevy C-10
350, TH400
« Reply #11 on: October 23, 2008, 11:29:07 am »
Got it and replied.
Offline 87GMC2WD
« Reply #12 on: October 23, 2008, 07:37:20 pm »
is there a way to replace just the rubber in those vent windows because mine like and i dont have 250 dollars to spend on a new one right now. plus i need both sides so it would be 500. But mine leak like a siv, air though not water, but its annoying when you are trying to drive down the road and listen to your 350
Offline hotrod24
« Reply #13 on: October 23, 2008, 08:05:35 pm »
yes you can replace the rubber it is easy you just need to take out the vent window
http://www.classicparts.com/1985-91-Vent-Window-Weatherstrip/productinfo/03-809B/
1978 pontiac grand prix...
Offline JJSZABO
« Reply #14 on: October 23, 2008, 08:47:02 pm »
I replaced the rubber in both of mine and the drivers side didn't take.  Still has lots of air noise and leaks water.  I assume the assembly is bad.  If I have to remove the vent window a second time to fix it, I decided to replace it with a new assembly.  This way i know it will be fixed - I hate doing things TWICE.  I figure after all the work I put into this truck, my time is worth something.
Jeff
86 Chevy C-10
350, TH400
