Body, Glass & Paint
cab question
Topic: cab question (Read 14432 times)
gmtech2
cab question
October 23, 2008, 12:55:20 pm »
anybody know how heavy a cab is or any good ideas on swaping one from a 79 to c15 78 k10 ive got an engine hoist and was trying to figure out a good way to get these switched. im kinda out of ideas any help would be appreciated
JJSZABO
Re: cab question
October 23, 2008, 12:59:16 pm »
I used 4 men and a boy. It is pretty heavy 350lbs+
Can you get three other people to help? It's easy with four people.
Jeff
86 Chevy C-10
350, TH400
hotrod24
Re: cab question
October 23, 2008, 01:07:11 pm »
you could try one of these
https://www.autobodytoolmart.com/p-11546-14246.aspx
1978 pontiac grand prix...
gmtech2
Re: cab question
October 23, 2008, 01:10:24 pm »
yeah i think ive got 3 friends!! i just was wondering what to expect weight wise. hopefully we can move it around pretty easy.
80stepsideguy
Re: cab question
October 23, 2008, 01:30:25 pm »
Here`s what i did
Got on and bolted down by myself w/o anyone helping me out.
thanks
pat
1998 Chevy 1500 S/B 2wd
gmtech2
Re: cab question
October 23, 2008, 01:44:06 pm »
thanks for the pics i think that should work pretty good. did you bold the 4x4 to the hoist or is it just sitting there?
Jiggy
Re: cab question
October 23, 2008, 11:36:51 pm »
I did something real similar except I instead picked from the bottom. With a bare cab, I used a 2X4, drilled holes at the locations of the rear cab mounts big enough to put a 3/8" eye bolt through with a toggle bolt on the end. Slip the 2X4 into the cab, drop the toggles with eyebolts through the wood and out the bottom. I used a small chain to connect the eye bolts with little slack. This chain drops onto the hook of your engine hoist. I then use 2 small 1" ratchet straps (1 to each of the front seat mount bolts) and run them to the lifting hook as well. Doing this lets me lift from the bottom, adjust for level with the ratchet straps, and gives far more height because the boom starts out so low. People always say it sounds cheap, especially the straps (I don't use crap straps) but keep this in mind.....assuming the bare cab weighs even 800 pounds, the front 2 straps are supporting about 500 pounds of the weight or 250 each. Anybody in the towing or rigging business will tell you that a good strap is just as strong as comparable size chain and the 250 pounds for this cab per strap is nothing. When I set the cab on the frame, I rest the rear on 2 small blocks just to get in and get the toggle bolts out then with 1 hand I can lift the cab to remove the block and set the cab right on the mount. This whole process is easy for a 1 person operation. Forgot to mention that I push the hoist in from the driver side. I do basically the exact same thing for the bed, placing the hoist at the rear and rolling the bed right onto the frame from the rear. I will try to remember to get pictures next time I do this (hopefully about 1 month) if anybody is interested.
hotrod24
Re: cab question
October 24, 2008, 12:07:51 am »
i am i will be taking my cab off soon i hope
Last Edit: October 24, 2008, 01:38:36 pm by hotrod24
Jiggy
Re: cab question
October 24, 2008, 12:15:10 am »
OKEE-DOKEE
gmtech2
Re: cab question
October 24, 2008, 08:09:08 am »
thanks for the help everyone. i pulled it last night used a 2x3 rectangle tubing i had laying around. Did it just like 80sstepsideguy illistrated it worked perferect. just put it across the cab and put the engine hoist underneath the center then i tack welded the tube to the hoist in the center and it went great had it off in about 15 mins. i was gonna take some pictures but my darn camera was dead!! Thanks again
ccz145a
Re: cab question
October 24, 2008, 08:36:02 am »
Or if you had some spare lumber and about 4hrs to burn, you could have done it like me...
(Just making it work with what I had on hand, definately not recommending this procedure. LOL)
cptn60
Re: cab question
October 24, 2008, 10:05:27 am »
Well guys whatever you do, please be safe. I tore my right bicep muscle(partially) lifting the bed off by myself. Safety first!
86 c10 shorty
80stepsideguy
Re: cab question
October 24, 2008, 01:24:03 pm »
Beds i wont lift off by myself, they sell this sling that has 2 bars and that attaches to your engine hoist and you jack it up and it lifts off.As far as cabs mine was pretty gutted so it was light and i moved sllloowwwwllllyyyyy and it was easy to doas long asyou take your time your good.I was told by a guy i bought the cab from he never heard of anyone doing what i did but hey it worked and no damages done to the cab or myself.
thanks
pat
p.s. Glad to help ya out GMTECH2
80stepsideguy
Re: cab question
October 24, 2008, 01:25:07 pm »
Quote from: hotrod24 on October 24, 2008, 12:07:51 am
i am i will be taking my cab and bed off soon i hope
Dusty,
thought your bed was already off?
hotrod24
Re: cab question
October 24, 2008, 01:29:30 pm »
oh sorry did i say that sorry i mean my cab but i did find a parts truck so i might be taking a bed off soon
Last Edit: October 24, 2008, 01:37:57 pm by hotrod24
Body, Glass & Paint
cab question
