Author Topic: under dash courtesy light  (Read 26643 times)
Re: under dash courtesy light
« Reply #15 on: November 16, 2008, 06:25:04 pm »
Maybe he meant not working?
Just check it with a test light.
Offline Prong
« Reply #16 on: November 16, 2008, 08:33:47 pm »
That fiber optic light works off of the bulb in the upper right corner of the gauge cluster (either the tach or fuel gauge depending on what you have).
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline farmallgray
« Reply #17 on: November 17, 2008, 12:54:27 pm »
So that is what that wire coming out of the cluster is for. I was wondering about that when I had the cluster out the other night. It wasn't hooked to anything, but I wouldn't have noticed the ash tray not being lit.
That reminds of another question;
does the heater control only have one bulb to light it up? Mine doesn't seem very bright even with a new 168 bulb.
1979 K-20 350/TH400
« Reply #18 on: November 17, 2008, 01:35:58 pm »
there is only one bulb in the climate unit.
Offline DnStClr
« Reply #19 on: November 17, 2008, 04:58:43 pm »
And it's dull on my truck too. Maybe a good place for an led.
Don
87 Chevy Silverado
Offline 82ChebySWB
« Reply #20 on: November 17, 2008, 08:26:38 pm »
Wow, I had no idea about this light. I just got my truck a few weeks ago, so I'll have to do some digging to see if this bulb might be burnt out.
Brian
'82 Chevy Silverado AKA Project "Cheby"
Offline JJSZABO
« Reply #21 on: November 18, 2008, 07:23:20 am »
I put a blue LED in my sons truck.  Looks good
Jeff
86 Chevy C-10
350, TH400
Offline murraygmc
  • 85 gmc 4x4
« Reply #22 on: November 18, 2008, 08:14:08 am »
i would say he just didnt put a t on not and hit the w .i'd like to see how you get to that ash tray light as whell how dose it stay shut mine stays open id like to shut it when not in use
85 gmc high serria 4x4
Offline dueprocess
  • My 8yr old's tonka toy!
« Reply #23 on: December 04, 2008, 12:01:35 pm »
works well also if you put the LED version of a 1157 in!!!!! Then it is bright as crap!!!! I love the light and wish my Yukon had one stock, i had to install one!!!!
1978 Chevy K10 / 454bbc / Dana 44 with chromoly axles / 6in susp & 3in BL / 38.50x15 Boggers(rims 15x14)!
Offline murraygmc
  • 85 gmc 4x4
« Reply #24 on: December 04, 2008, 12:23:19 pm »
how do you keep the ash tray closed mine stays open
