Author Topic: Bad Wiper Motor?  (Read 5422 times)
Offline Scootin 81 C20
    • My Pics
Bad Wiper Motor?
« on: October 30, 2008, 03:02:37 pm »
OK, here we go. I'm having a couple of problems with my wipers on my truck, an '81 Scottsdale, and I'm wondering if they are motor related. Problem #1: My wipers wipe about every 20-30 minutes when I'm driving or sitting there listening to the radio without messing with the wiper switch. Problem #2: My windshield washer doesn't work. I have the reservoir filled up, but it doesn't work. And, a little side question. What is turning the wiper knob supposed to do. Any help is appreciated.
Thanks
Benjamin.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Bad Wiper Motor?
« Reply #1 on: October 30, 2008, 04:01:27 pm »
turning  the wiper knob is the time delay adjustment...turn to right, faster cycle, turn to left, longer time b/w wiper activation.
As far as it runs every 30 mins or so, take a look under your dash on the firewall. There is a plastic cover for your washer motor.  If something in there is loose, a simple bump will activate your wiper motor.
AS far as your washer pump not working, do you hear the pump activated?  Check your lines etc..
« Last Edit: October 30, 2008, 09:30:04 pm by SgtDel »
Offline GoatBeard
« Reply #2 on: October 30, 2008, 04:04:05 pm »
Yeah, that little knob is REALLY sensitive.  You want to make sure it's turned off.  That alone might solve 1/2 of your problem.
    • My Pics
« Reply #3 on: November 06, 2008, 08:41:52 pm »
Thanks for the replys. I looked for the little panel under the dash and couldn't find anything. I tried turnning the knob, that didn't help. BTW, it was raining this morning and I found out that the first position to the right of off doesn't work. Anymore suggestions, or should I redo the wiper system?
Thanks
Benjamin.
Offline BigBlue
« Reply #4 on: February 03, 2010, 03:30:45 pm »
Sorry to dredge this up, but I'm experiencing the same problem and wondered if this had been resolved.
Offline frito-bandito
  • Hillbilly Deluxe
« Reply #5 on: February 03, 2010, 05:35:56 pm »
First thing I would try is the wiper switch, you may get lucky and that might solve all of your problems.
