Author Topic: speedo not right  (Read 9023 times)
Offline Cowboy_Customs
speedo not right
« on: October 30, 2008, 04:42:55 pm »
my speedo, starting at about 35+ is off. 73MPH is really 65 (GPS checked) 60 is 55, 55 is 51 and so on, but accurate at 35 and below.
I do have the wrong tire size 8.75 16.5 now, should have 7.50 16's. but according to this calculator http://www.1010tires.com/TireSizeCalculator.asp
it should not be this bad.
The rear end gears are stock, 4.10  Im assuming the tranny has either been rebuilt or just a shift kit. 4L80E Transmission.
I know of the older 350 and 400 its just a simple speedo gear change, been there done that, but what about this one?
Dream Truck:
1991 GMC Crewcab Dually Western Hauler conversion 454TBI 4L80E 19.5's
http://community.webshots.com/user/Cowboy_Customs
Re: speedo not right
« Reply #1 on: October 30, 2008, 05:04:58 pm »
None of these were that accurate, the 4L80E uses a VSS for the Speedo.  I will have to look up on the correction proceedure
« Reply #2 on: October 30, 2008, 06:00:37 pm »
Thank you Capt.! Itd be nice if it was somewhat close ya know?
Dream Truck:
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: October 30, 2008, 09:34:32 pm »
I read somewhere that 90 and 91 models used an electronic speedo, different than any other years, which used the cable/gear.
My 91 GMC Sub speedo messed up about a month ago (reads buried) and I have to go get it fixed....the cruise and odometer work fine.  Go figure.
« Reply #4 on: October 31, 2008, 10:00:14 am »
Andy,
that is what I meant by VSS for the speedo,
« Reply #5 on: October 31, 2008, 10:30:28 am »
One thing to keep in mind is if your accurate at 35 or below, how is the odometer at the higher speeds?  I have had some the acted like yours but the odometer was dead nuts mile after mile.  Mine turned out to be the speedometer itself.  Just my $.02
« Reply #6 on: November 05, 2008, 07:22:23 pm »
Hmm... good point. I will have to check it, fortunatly there is a "measured mile" deal on the highway like 2 miles from here. Thanx!
Dream Truck:
« Reply #7 on: December 03, 2008, 09:59:39 am »
OK, finally did the measured mile, and the Odometer is off exactly 1/10th per mile traveled.
1 mile = 1 1/10th mile recorded by the odometer.
Trip reset doesnt work either, but I would assume thats a whole other issue with the reset spring.
Dream Truck:
