Author Topic: Cab questions!  (Read 5829 times)
Offline unbludictable
  • Low Down Blu
Cab questions!
« on: October 31, 2008, 09:21:31 am »
Hey guys it's been a while, but here I go! I want to keep my 76 GMC but the cab is like swiss cheese in the floor, so I bought a complete 79 Chevy body for parts. The 79's cab is in good condition but my question is:
Can I tell what works before I switch cabs? (stuff like heat, turn signal, flashers, and so on)
Is this a difficult swap?
I've never done this before and I ain't no mechanic, but I'm learning!!
Re: Cab questions!
« Reply #1 on: October 31, 2008, 09:56:24 am »
No way to tell unless you have an operational donor.
If they work on your 76, just gut the 79 and swap everything over.
Offline hotrod24
Re: Cab questions!
« Reply #2 on: October 31, 2008, 12:20:15 pm »
i have a 73-74 cab and i am switching to 78 and 79 stuff
1978 pontiac grand prix...
  • Low Down Blu
Re: Cab questions!
« Reply #3 on: November 01, 2008, 06:19:10 pm »
Can I hook up my battery and test it?
Offline ccz145a
Re: Cab questions!
« Reply #4 on: November 03, 2008, 10:50:21 am »
Quote
Take an ohm meter and convince yourself there are no shorts first. I found it hard to test everything, but I pluged up the three firewall connectors in succession and tested for shorts and finally just hooked up the battery and looked for smoke. All was well.
Offline topside
Re: Cab questions!
« Reply #5 on: November 23, 2008, 10:14:58 am »
Heat/defrost will require a running engine, but you should be able check the heater core for leaks by running water through it. For the electrical, 12V power, the full harness with grounds, and being able to reproduce ignition-on, and you can check the system. Gauges will require whatever they connect to (fuel tank, engine) unless you can simulate the input another way. From what I've read on these trucks, gauges that are reading at max levels with no power to them are probably bad; but they're available, and can be swapped used as well.
Offline joesgarage71
  • Wrench
Re: Cab questions!
« Reply #6 on: November 25, 2008, 05:59:57 pm »
Heat/defrost will require a running engine.
You can use a hand op vacuum pump for checking the vents/hot and cold door operations. Heater cores are cheap enough to install a new one, the rest can be repaied/replaced if bad easy enough. Get your self a helms overhaul/service manual for your year.
