Author Topic: hinge stop/spring install question  (Read 12255 times)
Offline vince311
« on: November 04, 2008, 01:54:48 pm »
It appears my door hinge stop/spring is missing. ugh.
I've got a spare spring... wondering if there is a trick to installing it? I assume I will need to remove the door. Is it best to remove the hinge all together, and put in a vise? OR can the spring be reinstalled while on the truck?
'82 Chevy shortwide, 2wd, 350/350 - Sold
Offline silvrbreez
Re: hinge stop/spring install question
« Reply #1 on: November 04, 2008, 05:13:06 pm »
I've got to do this to my driver's side door too.  I'm anxious to hear what folks say.  I appears you can just take the door off and place it where it needs to go on the spring, but I could be wrong.
Offline vince311
« Reply #2 on: November 04, 2008, 05:19:44 pm »
the "s" shaped spring sits in little grooves...on the hinge. It has a lot of tension....and was a pain getting it out. Putting it back into the hinge...may take some finesse.
« Reply #3 on: November 04, 2008, 06:01:37 pm »
It has been a while since I did this (a LONG while) but if memory serves me correctly I took the hinge off, and it was a pain to do.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #4 on: November 04, 2008, 07:07:54 pm »
Make sure you have the right spring, there is a left and a right.
There's a socket/tool to get to turn the spring:
Here's the tool in action, in this pic the hinge is in the closed position; it will need to be in the open position for this to work:
for removal: You put the tool on the spring and twist is away from the hinge, then you tap the other end of the spring towards the end the tool is on until the spring will clear the hinge when you release the tension.  Then let the tesion off and you're done.  The tool must be used on the bottom of the hinge spring because you can't tap it the other way because of how it hooks into the hinge.
This pic shows the end the tool must be used on, the square end of the spring, the tool won't work on the rounded end.
for installation:  hook the square end in the hinge and then put tension on the spring and once it clears the hinge tap it back down (Make sure you don't tap the other end so far it comes loose or you'll learn some new dirty words ;D) and relese the tesion and you're done:  The last pic is of a LH UPPER hinge, just for reference.  Having a helper would do great too because you need two hands to work the spring tool and the helper to tap the spring for you.
The last one i did, was on the truck, with the door off, but it was a PITA.  If you're not worried about the paint around it, it's not so bad.  If you have great paint and want to save it, it almost certainly has to come off the truck alltogether.
I don't know where to get the tool, My dad bought that one before i was born, and gave it to me when he gave me his old '77.
Good luck!
« Last Edit: November 04, 2008, 07:14:23 pm by 78 Chevyrado »
« Reply #5 on: November 04, 2008, 07:55:32 pm »
I have done these with two pry bars, and a ball peen hammer on the truck with the door on. Slide the bottom hook up in the notch beyond so the top can clear. Then use a pry bar to turn it in, hold it with your hip, use another pry bar above it, and give the pry bar a swat with the hammer to slide the spring down.
 I have never seen one of those tools! Looks like it works pretty slick.
« Last Edit: November 04, 2008, 09:59:34 pm by Blazin »
Offline HAULIN IT
« Reply #6 on: November 04, 2008, 07:58:36 pm »
Nice post Kenny! A creative person could probably make a tool to do that job after seeing yours.
« Reply #7 on: November 04, 2008, 11:39:13 pm »
Excellent pics Kenny.  I think I used a couple of vise grips and a pry bar.
Offline silvrbreez
« Reply #8 on: November 05, 2008, 07:30:44 am »
Very good, nice pics.  Thanks for the help.
