Author Topic: rear disc brakes  (Read 20327 times)
Re: rear disc brakes
« Reply #15 on: August 19, 2009, 05:12:48 pm »
As Lorne pointed out, the overal width is close enough for the swap.  I don't know what type U-joint it would use, but that would be a minor issue to find out, just look it up.
Offline brlarl
  • Big Bad Bowtie!!!
« Reply #16 on: August 20, 2009, 08:14:05 am »
One other question, when I mock it up, can you tell me at which loction the spring pads should be in?  I mean where should they be in relations to the pumkin for the driveline angle?  If I can figure that out then everything else would fall in place.  I picked up a complete unit out of 96 Impala for $225.00 and the car only had 49,000 miles on it.  I poped the cover off and everything looks great inside it.
Don't wear a tux without the BOWTIE!!!
« Reply #17 on: August 20, 2009, 11:06:32 am »
Not sure I am following you here.  Are you wanting to know where the spring pads should be located?
I would use the factory one and measure off of it.
Offline brlarl
  • Big Bad Bowtie!!!
« Reply #18 on: August 20, 2009, 12:26:54 pm »
Yes, I need to know at what angle should I weld the spring pads (in relation to the tansmission output shaft angle) on the Imapla Differential?  I want to make sure I have the correct drive angle so my driveshaft does not bind up. Also if I do have to change the rear u-joints, how would I go about doing that if divehaft will still need the original style u-joints and the Impala diff will need what "it" calls for?  Will I be able to switch out the Pinion Yoke on the Impala diff to the one from my original truck diff to just use the original u-joints?  Are the splines the same on the Pinion gear to mount the yoke?  Thanks
« Reply #19 on: August 20, 2009, 05:41:49 pm »
You need to set the angle to match that of the output of the transmission.  Should be around 3-5 degrees up.
I would see what u-joint it takes and see if the hybrid joint will work, or just have your driveshaft end changed to use the Impala joint.
Offline brlarl
  • Big Bad Bowtie!!!
« Reply #20 on: August 21, 2009, 09:08:29 am »
Thanks Capt.
