Author Topic: rear disc brakes  (Read 20326 times)
Offline tusk
rear disc brakes
« on: November 06, 2008, 02:08:35 pm »
i may have put this in the wrong section,but i was wondering what have ya'll been doing as far as rear disc conversions,i was wondering why i couldnt get some impala rear rotors and use them,as far as the calipers,in the 4x4 world,we have been using 1/2 front calipers on homemade brackets, with 3/4 4x4 rotors,any ideas or pics,
Offline tusk
Re: rear disc brakes
« Reply #1 on: November 06, 2008, 02:12:39 pm »
well ifeel like a goof,wheni did the search on here i came up empty handed,i typed in rear bake conversion,no reason there was no matches ::)
« Last Edit: August 19, 2009, 05:09:15 pm by Captkaos »
« Reply #2 on: November 06, 2008, 02:53:18 pm »
There are a few companies making these conversions CPP, SSBC.  But if you want to make your own you can use Impalla SS rear rotors and calipers and make you own bracket.
http://www.73-87.com/7387garage/chassis_suspension/reardisc.htm
Offline tusk
« Reply #3 on: November 06, 2008, 03:24:10 pm »
I just called my guy at the parts store and rear rotors are 28.00,but the rear calipers are 62.00 ea,unloaded,wow,i will probably use the ss rotors,and make my own brackets and use the 1/2 ton caliper that can be bought for 25.00 loaded,when i start on this part of the project i'll post up some pics
« Reply #4 on: November 06, 2008, 04:17:33 pm »
The downfall to using truck calipers is there is no parking brake..
Offline Dragon
« Reply #5 on: November 06, 2008, 06:28:08 pm »
Hey now! If I go out to my car, and find my brakes gone, I'll no where to look for them :o ;D :P
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline HAULIN IT
« Reply #6 on: November 06, 2008, 07:27:10 pm »
Chris, Going with the Impala calipers on home-made brackets...there wouldn't be any parking brake either.
« Reply #7 on: November 06, 2008, 11:14:00 pm »
If you see the writeup I posted Mike has the bracket dimensions for 80-85 Cadillac Seville calipers with P-brakes.
Offline tusk
« Reply #8 on: November 07, 2008, 07:08:27 am »
who needs a stinking parking brake ;D,seriously though,Ive been driving a little of 20 years and every car/truck that was a automatic,Ive never used the parking brake,has the impala got the inside the rotor hat parking brake system,like the explorers,that would be a neat conversion,after doing a little research Latinate,I'm going to order a set of the speedway rotors and hats,make my own brackets and use the metric front gm calipers,just hope it will be worth it over the drums but i doubt it,if it goes according to plan without the m/c or p/v i should have around 200.00 in the conversion
Offline HAULIN IT
« Reply #9 on: November 07, 2008, 09:48:40 am »
Chris, I misunderstood the way you worded the sentence that you were thinking of using Impala calipers also, but posted the link for help with making the bracket on the axle housing, Sorry.
 Yes Tusk, the Impala has a drum inside the rotor, the backing plate has the "regular" GM car axle bolt pattern, but uses the 5" wheel bolt pattern like the 2wd trucks. Lorne
« Reply #10 on: November 07, 2008, 03:15:14 pm »
NO problem I read it again and realized it was confusing.  You could modifiy the Axle tube  to take the impala backing :D
Offline HAULIN IT
« Reply #11 on: November 08, 2008, 08:03:54 am »
That is something I had questioned before, me & someone on here pondered that...but I never went any farther. I should be able to check on that. I have complete set of Impala brakes on a shelf & the ends of the axle tubes I cut off the 8.5 rear when I made the 9" should still be in the scrap bin. Does anyone know (or can check) the axle set-out (distance from the face of the backing plate flange to the face of the wheel flange on the axle) on the 8.5 & 12 bolt truck rear? The Impala is 2 3/4", It would be nice if the truck was more, it could allow for a spacer to be machined to fill in the recess in the back backing plate for the flange to seat.  I'm also concerned about the "snout" sticking out where the bearing goes...they made the bolt pattern bigger on the truck, I'm assuming to have clearance around a bigger bearing? There may not be enough clearance around the parking brake set-up to allow for it. Over the next day or Two I'll check it out & report back, unless someone has already done so, Speak up. Lorne
Offline HAULIN IT
« Reply #12 on: November 10, 2008, 07:56:59 pm »
Guys, I did some checking on the Impala backing plate/disc brake caliper bracket this evening. At a glance, it looks more positive than I had expected. The back side has a large flat area, so the bigger truck flange isn't a problem. The parking brake workings are outward far enough to clear. The only thing that is a little questionable is a groove/step area that will likely be close to where the truck mounting bolts will be. This may require a plate on the inside to have the bolts sit on to be flat. The center hole will need opened up for sure. Another nice thing is both calipers are on the back of the axle (not one in front like many set-ups).
 Does anyone have a truck rear with the wheel off to measure the axle set-out? If it's 2 3/4" like the cars...this could be interesting.
 On a side note, especially if your truck has a 2 something gear, non-posi rear...a complete Impala rear could be adapted, the width is very close, wheel bolt pattern is the same. All you would need is some spring perches & shock brackets to end up with a 3.08-3.42 gear posi rear with good disc set-up (aluminum PBR calipers with vented rotors) just a thought?
 If I was a guy in the planning stages for rear discs on my truck, I would defiantly research the Impala backing plate plan some more! Have Fun! Lorne
« Reply #13 on: November 10, 2008, 10:18:47 pm »
I have one out of a truck but I have to get it out of the back of my crew cab.  I can get you any measrement you want tomorrow evening.
Offline brlarl
  • Big Bad Bowtie!!!
« Reply #14 on: August 19, 2009, 03:31:52 pm »
Sorry to dig this one out of the cemetery but I have been looking for an alternate way of putting disc brakes and a posi unit on my C10 without spending too much $$$$ on it.  Can any one tell me the measurements of an Impala rear end vs. the 8.5 12 bolt in my C10?  Other then the spring pads and shock mounts what are the other down fall to making this work??  What about the section where the driveshaft mounts to the diff. will the factory C-10 u-joints sit in?  If this will fit, this is more economical for me to use instead of having my rear end rebuilt to a posi and purchasing the brake conversion kit.  Haulin It, I saw you were looking into this.  Did you ever have any luck?  Any help would be great.  Thank Guys
Don't wear a tux without the BOWTIE!!!
