Author Topic: No Taillights  (Read 4820 times)
Offline Unofficial
No Taillights
« on: November 09, 2008, 07:37:49 pm »
A friend who happened to be driving behind me brought a problem to my attention. When my lights are on, my taillights aren't. My brake lights, blinkers, and hazards work, just not the taillights that are always supposed to be on. I haven't checked anything because I don't know where to start. Where should I begin to look for problems?
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
Offline Dirtydog
Re: No Taillights
« Reply #1 on: November 09, 2008, 10:34:44 pm »
Sounds like a bad connection, do you have a tester to see if you are getting current to the taillights?
-Josh
Re: No Taillights
« Reply #2 on: November 10, 2008, 07:29:43 am »
Your brake, blinkers, and hazards are on a different circut than the your tail lights. Do your front parking lights work? Dash lights? If not I would check the fuse. If they do first thing I would check is the plug between the bed and the frame. There is a ground wire behind the right tail light into the sheet metal but if it was bad it would affect all the rear lights. Still wouldn't hurt to clean and reattach it. If its not the plug in the rear I would follow that harness up the frame to where it plugs into the bulkhead fitting in the fire wall behind the fuse box. One bolt in the center of it I think its 5/16" or 3/8" and you can unplug all three wire harness's.
Offline Unofficial
Re: No Taillights
« Reply #3 on: November 10, 2008, 08:53:17 am »
Alright thanks for the guidance, I'll check it out after school today.
MSD ignition
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: No Taillights
« Reply #4 on: November 10, 2008, 01:16:33 pm »
I don't know how the squirrels are in Wisconsin, but, here in Va, there was a time when the squirrels chewed through the wires under the bed of my pickup. I was so mad I bought a squirrel/rabbit trap and trapped 24 squirrels and sent them to a park on the other side of the interstate from me.  No more chewed wires.
Offline Unofficial
Re: No Taillights
« Reply #5 on: November 10, 2008, 04:26:27 pm »
It's funny that you should mention squirrels. My dad and I have a pretty severe squirrel problem in the backyard that we take care of... I don't think the wires are chewed up, I gave them a look and everything looked fine.
MSD ignition
