Author Topic: dumb question  (Read 4743 times)
Offline murraygmc
  • 85 gmc 4x4
dumb question
« on: November 12, 2008, 01:32:21 am »
i have a 85 gmc sierra 4x4 and it has a 6 cyl the rings are shot wanting to put a 350 in it. its got a 4 speed manual trans my question is from what range of years will a 350 sit and bolt right in i know ill have to get a new radeater an fan shroud thanks
85 gmc high serria 4x4
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: dumb question
« Reply #1 on: November 12, 2008, 01:54:01 am »
any year 350 will work. You need to change the engine mounts on the frame though.
Re: dumb question
« Reply #2 on: November 12, 2008, 09:45:21 pm »
85 and newer will bolt right in because they are a one piece rear main seal engine. A two piece rear main seal motor will work but you will have to get a fly wheel that fits a two piece rear seal crank. If it were me I would swap in a bigger diameter clutch, which might require a bigger flywheel anyway.
Offline eventhorizon66
Re: dumb question
« Reply #3 on: November 13, 2008, 10:14:23 am »
I thought '86-up were one-piece rear main seal.
'85 C10 SWB 350 700R4 TKO600
Re: dumb question
« Reply #4 on: November 13, 2008, 10:42:08 pm »
I have heard that before too, but I had an 85 built 5-85 and it was a one piece rear main seal.
Offline murraygmc
  • 85 gmc 4x4
Re: dumb question
« Reply #5 on: November 16, 2008, 03:35:13 pm »
whell thanks 4 the info guys
