Author Topic: Electronic to Mechanical Speedo Conversion  (Read 7677 times)
Offline 81Cheyenne
« on: November 19, 2008, 12:38:52 pm »
I'm changing out trannys from a 350c to a 700R4.  The 700R4 that I'm putting in is set up for an electronic speedo and looks like it has a purple drive gear.  My mechanic has found a mechanical drive housing.  I'm putting in a 3.73 rear end and will be running 29" (235/75-15) tires.  What size driven gear will I need?
Offline joesgarage71
  • Wrench
Re: Electronic to Mechanical Speedo Conversion
« Reply #1 on: November 19, 2008, 03:20:58 pm »
« Last Edit: November 19, 2008, 03:38:58 pm by joesgarage71 »
« Reply #2 on: November 19, 2008, 04:26:48 pm »
Offline 81Cheyenne
« Reply #3 on: November 20, 2008, 12:52:37 pm »
here is another one:
http://www.73-87.com/7387garage/drivetrain/speedo.htm
Yep. I saw that. But did the later model 700R4's with the electronic speedo setup have a different color drive gear?  I haven't had a chance to go over to the garage to see it but my buddy said that it looked purple.
« Reply #4 on: November 20, 2008, 02:20:13 pm »
should use the same.
