Author Topic: A new buddy of mine that wants to be a member heres crew cab dually video  (Read 13802 times)
Offline hotrod24
Re: A new buddy of mine that wants to be a member heres crew cab dually video
« Reply #15 on: November 25, 2008, 04:27:29 pm »
nice man welcome you will be a big help here
« Last Edit: December 01, 2008, 10:22:11 am by hotrod24 »
1978 pontiac grand prix...
Offline hotrod24
« Reply #16 on: November 25, 2008, 04:28:52 pm »
i liked the burn out
« Last Edit: November 25, 2008, 04:30:28 pm by hotrod24 »
Offline 80stepsideguy
« Reply #17 on: November 27, 2008, 10:12:42 pm »
Thanks guys, I did finally make it on the site. Glad you all liked the burnout, a little childish, but a direct representation of what big block power can do. I have built several Chevy's ranging from a 1973 Cheyenne C-30 454, auto, two wheel drive and 12 foot flatbed. I loved that truck, drove it for a good many years. There were several in between, all within the 73-85 range. The one in the video I got when I was still in high school and it had a 350 and 2 wheel drive. My mother ended up with it after a few years to tow her horse trailer around, and then it was parked and sat for about 7 years in one of her fields. She called me one day and asked if I wanted it. If not, it was getting junked. I have to say it looked pretty miserable, but the chassis was mint. So "project the beast" was borne. I always thought it would look tough with 4-wheel drive and a lift, and a friend of mine was junking an 85 single cab dually 4-wheel drive, with no engine. I'm shure many of you know that the 76 crew cab chassis has no provisions for the swap. It took the winter with lots of measuring and parts fabrication but it turned out real nice. Of coarse the 350 had to go, so I built a 454 4-bolt main, .060 over with 049 heads, Manley 2.19-1.88 valves, Comp 1.550 springs and rotator eliminators were added. Bowl blended, ports cleaned and gasket matched. Combustion chambers were brought down to 118 cc's and the block was zero decked to give the Speed Pro 2645's a comp ratio of 10:1. I went with a Comp Xtreme 4x4 with 210-218 deg.@.050 and .505-.515 lift at valve. Comp pro magnum roller rockers and custom length pushrods brought the valvetrain together It makes tons of low to upper mid range power, just perfect to motivate that big dually. It was topped of with a Edelbrock Performer manifold and Carter 750 carb. I also went with Hooker comp headers, 2.5 dual exaust with balance tube and Flowmaster 50's (which I'm not to crazy about their sound, should have went with 40's). The trans is a TH 400, which I rebuilt with new internals, heavy duty sprague and shift kit. It has a NP 205 transfer case, Dana 60 front, and 70 rear with 3.73 gears. The body needs a little work and a nice paint job, but all in good time. And yes, I am from New York. Anyway, I look forward to spending some time on the forums and contributing what I can. See you all out there.  JW454.
Welcome jay,
 so glad you are here finally.. Question the 454 your built in your you tube video on the stand.Is it finally in the camaro? I cant wait to see that car rock and roll ;D
thanks
pat
p.s.s hope you n your family had a fantastic thanksgiving
« Last Edit: November 29, 2008, 06:37:58 pm by 80stepsideguy »
1998 Chevy 1500 S/B 2wd
Offline jw454
  • My bigblock dually diesel killer
« Reply #18 on: November 29, 2008, 05:57:33 am »
Thanks for asking, but I probably wont have it in until mid winter and hopefully by spring the car will be ready for pavement pounding.
Nothing says power like cubic inches!
