Author Topic: pinion angle?  (Read 11132 times)
Offline kustom71
pinion angle?
« on: November 21, 2008, 06:48:05 pm »
Hi GREAT SITE!!!!
I have an 84 c-10 and Im going to do an axle flip on but I dont know if I this will change the pinion angle or not?I guess I could just check before and after it should be the same right?
Any help would be appreciated!!
Re: pinion angle?
« Reply #1 on: November 21, 2008, 07:27:06 pm »
Who's kit are you doing the flip with.  Are you long bed or short bed?
If it is a quality kit the angle will be built into the mount.
Offline 85MudMonster
Re: pinion angle?
« Reply #2 on: November 21, 2008, 10:05:55 pm »
an axle flip? is that for lowering or something?
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Re: pinion angle?
« Reply #3 on: November 21, 2008, 10:17:53 pm »
Yes it lowers the truck.
Re: pinion angle?
« Reply #4 on: November 21, 2008, 10:20:43 pm »
Cool. I figured, but I thought I'd ask to be sure. I'd only ever heard of the Shackle Flip kits for lifting the truck....
Dan
Offline kustom71
Re: pinion angle?
« Reply #5 on: November 23, 2008, 02:15:05 pm »
Sorry about not gining all the info:
84 c-10,longbed,bell-tech flip kit!
Re: pinion angle?
« Reply #6 on: November 23, 2008, 07:29:44 pm »
Long beds sometimes need shimming on hanger kits, but the flip should be fine.
Here is a long post on verifying/checking the pinion angle.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7869.0
Offline kustom71
Re: pinion angle?
« Reply #7 on: November 24, 2008, 07:35:44 pm »
Thanx One more question if i can,I know there is no definite amount of inches the rear of the truck will drop it depends on spring packs(overload removed or not).I plan to leave the spring pack together and install the flip then i will measure to see what im left with.My question is if I end up getting a 5 or 6 inch drop what would be the best way to bring the front down as I have not ordered anything for the front yet but have researched and found the biggest spindle drop to be 3" (i think)What would be the best way to get to 4 inches if I need to(1"spring or split the difference in spring and spindle)???I need this truck to be able to be aligned correctly with no problems as I will drive it eveyday!
Thanx again
Re: pinion angle?
« Reply #8 on: November 25, 2008, 03:41:19 pm »
Measure the rear before and after the flip kit if you want an accurate measure of the drop. (measure both times at the same exact place.)
for the front to be level with the rear on a flip, you need 3" spindle and either 1" OR 1.5" springs.
if you want it to be raked, you need the amount of the rake.
Generally 4/6 sits level and 5/7 sits level.
Offline kustom71
Re: pinion angle?
« Reply #9 on: November 26, 2008, 07:47:17 pm »
Thanx for all your help,Hopefully I will be starting this soon!!
Offline N2TRUX
Re: pinion angle?
« Reply #10 on: December 25, 2008, 12:03:41 am »
I know this is an old post, but it sounds like you are still in the planning stages. One thing that wasn't mentioned here is what size wheel you are running. If you go with a 3" spindle and your running 15x8's on the front you will have to deal with clearance issues on the A-arms. Your going to have to trim or grind the A-arm or run a narrow 15" wheel. A larger diameter wheel can solve that issue as well.
Offline kustom71
Re: pinion angle?
« Reply #11 on: December 26, 2008, 05:00:00 pm »
Thanx for the info!
Just started and finished the c-notch today,im just bolting it in for now wanted to weld it but if I have to change something its a big hassle..
Im thinking about wheels I have a set of American racing wheels decent shape I got layin around but they are 5x4.75 bolt pattern and Im not sure about using adapters maybe someone can chime in?Dont really have the dough for new wheels and tires right now.Need to replace my leaf spring bushings then the rear suspension stuff will be done.
Thanx again
