Author Topic: Backfire issues  (Read 13491 times)
Re: Backfire issues
« Reply #15 on: November 23, 2008, 08:37:38 am »
Check the firing order and make sure you didn't cross #5 and #7
Offline greenkeeper
Re: Backfire issues
« Reply #16 on: November 23, 2008, 09:37:47 am »
I changed the plugs and wires when I installed the new carb.  The plugs were so bad that I think two of them weren't even firing anymore since the electrodes were worn down to nothing and another one was fouled pretty  bad.  The truck also had a small exhaust leak at the manifold in one of the emmission air tubes.  I plugged that up and thats when the problems started ??? Go figure.  I'll recheck to make sure #5 abd #7 are not crossed.  After that im not sure what to check.
Offline DnStClr
Re: Backfire issues
« Reply #17 on: November 23, 2008, 08:44:59 pm »
Could it be that by plugging the leak it allows the fuel-rich exhaust gases to enter into the hot exhaust pipe , where combustion takes place (backfire).
Don
87 Chevy Silverado
Offline greenkeeper
Re: Backfire issues
« Reply #18 on: November 27, 2008, 12:21:17 pm »
Ok, so I called a local supplier for a new muffler for the truck and the list on it was $365. :o  I asked him if it was made out of  gold or platinum. He tried to match up a universal but no luck.
Where can I find a cheap muffler for my 88 R-30 350 dump truck?
Re: Backfire issues
« Reply #19 on: November 27, 2008, 01:02:26 pm »
Any muffler shop worth going to can put in a replacement muffler. To find an exact replacement, maybe not, but one that will fit, if they cant do it, leave. They are incompetent.
