Author Topic: 79 FULL-TIME 4X4  (Read 24462 times)
Offline k-star
79 FULL-TIME 4X4
« on: November 29, 2008, 12:36:57 pm »
I WAS WONDERING IF ANYONE KNEW HOW TO CONVERT MY FULL TIME TO BEING ABLE TO UNLOCK.  I HAVE HEARD OF KITS THAT WILL DO THIS, HOWEVER I HAVE NOT FOUND THEM.
Offline 75chevy scotty
Re: 79 FULL-TIME 4X4
« Reply #1 on: November 29, 2008, 01:30:03 pm »
Milemarker part number 501 get at summit for 44.95 or the shaft replacement by mile marker don,t know the part number but Both are fairly easy to install I would go with a new shaft kit so you don't have to deal with the needle bearings with your old shaft. Also need manual hubs too.
« Last Edit: November 29, 2008, 08:03:49 pm by 75chevy scotty »
Offline fast823
« Reply #2 on: March 01, 2009, 11:52:46 am »
With that kit from mile marker do you still have to buy hubs to lock it in 4wd or does everything you need come in the kit and you uses the shifter on the floor to shift in 2wd or 4wd  Sorry for the dumb questions. I also have a 79 looking to convert.
Offline Russ130
« Reply #4 on: March 06, 2009, 09:07:08 pm »
With the kit that Captkaos is referring to you will control your 4wd and 2wd both high and low range from the floor shifter. Basically your loc positions become your 4wd positions.
Offline fast823
« Reply #5 on: March 12, 2009, 03:02:11 pm »
If you order the 501 kit do you or can you also put the shaft in that 75 chev is talking about? Does someone have a part number for the shaft?
Offline onesmokinduramax
« Reply #6 on: March 15, 2009, 12:28:48 am »
Mile Marker kit at Summit:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MMK%2D502&N=700+4294843457+4294908216+115&autoview=sku
Glad some one asked this ? I was wanting to know the same thing... How hard is it to do this  any one here have a  write up and pic on doing this?
04 Chevy Duramax LLY crewcab 4X4
Built ATS Allison Upgrades  making around 500HP!
75 chevy 3/4 ton 4x4 its got a built 350 with dana 44 and a lift and a 86 GMC body
Offline biggietalls
« Reply #7 on: March 17, 2009, 12:56:08 am »
I also have the np-203 and would like to get some manual locking hubs but would like to stick with the 203 instead of swapping out the whole case with either a 205 or 208 and also I need them for a 10bolt front
79'/88' k10 p/u
built 350/350/203
4:88 gears
msd. 6al
4"super lift
31"courser at2's
cobra 29 ltd classic-lil' wil
« Reply #8 on: March 17, 2009, 02:24:24 am »
you can swap out the hubs no problem but you still will be turning the ring and pinion if you don't do the part time swap
http://southjersey.craigslist.org/pts/1064130990.html
Offline biggietalls
« Reply #9 on: March 17, 2009, 02:43:18 am »
soo besides the ring and pinion wearing faster what other cons are for doing the swap? and your link didnt work
79'/88' k10 p/u
built 350/350/203
4:88 gears
msd. 6al
4"super lift
31"courser at2's
« Reply #10 on: March 17, 2009, 03:56:43 am »
He must of sold it. just swapping the hubs you will be still turning everything and your gas millage wont really increase unless you do the swap then you will get better mpg. I'm not sure but i think tire wear will also slow down in the front
Offline biggietalls
« Reply #11 on: March 17, 2009, 11:41:35 am »
well as far as mpg i get like 9-11 and that alone is kind of a pain so if i were to swap out which case would be better the 205 or the 208?
79'/88' k10 p/u
built 350/350/203
4:88 gears
msd. 6al
4"super lift
31"courser at2's
« Reply #12 on: March 18, 2009, 02:32:45 am »
you don't need to swap the t case. just get the kit and put it in. but if you wanted to swap i would go with the 205
Offline biggietalls
« Reply #13 on: April 25, 2009, 01:51:35 pm »
soo i found a np 205 for a good price but its outta an f-150 will it still work?
79'/88' k10 p/u
built 350/350/203
4:88 gears
msd. 6al
4"super lift
31"courser at2's
Offline Russ130
« Reply #14 on: April 26, 2009, 05:38:47 pm »
Personally I would just put in the locking hubs and forget about the conversion to the t-case. I have a converted 203 and plan on switching it back to full time. The reasons are very simple first if the front hubs are disconnected yes you will be spinning the ring & pinion but that is actually a good thing for lubrication purposes. The gas mileage is not that critical once the hubs are unlocked and neither is the tire wear. The big bonus is the 203 in fulltime form has the ability to differentiate between the front and rear axles. When you install the conversion that ability is lost and wear of the drivetrain parts is considerably more. So to me the best of both worlds is to have the locking hubs installed but not the conversion to the t-case.
