driving issues
Topic: driving issues (Read 16663 times)
cwilson jr
driving issues
November 29, 2008, 02:38:55 pm »
all of a sudden my pickup is riding horribly. it will start off fine at very low speeds and right away it will start shaking and swaying mildly. then at faster speeds, and especially when braking it is so bad it sort of feels like a boat in very rough water and that i have a tire about to fall off. again it does this at both moderate speeds and gets even worse while braking. the tires and brakes are just shy of being brand new. tire pressure is good and lugs are tight. obviously my truck pulls when i take my hand off the wheel, but is probably being caused by the problem at hand and not the alignment itself. right? or could a misalignment do this something this severe?
Re: driving issues
November 29, 2008, 03:14:13 pm »
Did you check the front end? Bad or loose wheel bearings?
bigkountry
Re: driving issues
November 29, 2008, 04:53:01 pm »
When the new brakes where put on, did you have the rotors turned or replaced?
I have never seen the alignment off make it handle poorly, just veer to one side or the other.
Donut
Re: driving issues
November 29, 2008, 06:37:08 pm »
Quote from: VileZambonie on November 29, 2008, 03:14:13 pm
+1, Sounds like tie-rod ends. Whatever it is, get it fixed ASAP.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
cwilson jr
Re: driving issues
November 30, 2008, 08:09:01 am »
that's more on the line of what i was thinking, something in the front end, however i don't know a whole lot about the suspension aspect of the vehicle. is there a way to get under there and inspect the tie rods and tell if there is something wrong. i also had the driver's side front tire blow out on me a while back and didn't think anything of it because all of the tires were in pretty bad shape and needed replaced. i threw the spare on and later it eventually blew out on me as well. i dismissed this as well just thinking it blew out because of dry rot, it was all cracked, etc. but held the air perfectly fine, so i left it on there. i have since gotten new tires all the way a round and later this issue is occurring, which now that i think about may very well be connected.
Re: driving issues
November 30, 2008, 08:47:08 am »
Do a dry park check. Have an assistant rock the wheel back and fourth and observe the steering shaft, gear box, frame, suspension and steering components.
Next jack up the front end (2wd under the lower control arm) and check the ball joints and wheel bearings for play.
Re: driving issues
December 01, 2008, 12:02:44 am »
First did you ever replace all the tires? could be a couple problem one broken wire in the tire will cause it to shake at high speeds. second is there any squeaks when driving and like said b4 jack up the drivers front and shake it, then the passengers side you should be able to feel a difference. could be tie rod or wheel bearing.
joesgarage71
Wrench
Re: driving issues
December 03, 2008, 09:29:53 am »
Could have a broken belt in one of the front tires, and or the caliper is sticking.
Do you smell hot brakes after a drive, and is your rotors turning blue? This condision will run the grease out of the bearings and they will go south making what you are experiencing now. Dangerest at any speed!
SUX2BU99
Re: driving issues
December 04, 2008, 04:44:13 pm »
The tire malfunction is a definite possibility. One of my front tires developed a rather large 'blister' on it. Something broke or split internally and this happened. For a long time I couldn't figure it out. It would vibrate a lot at lower speeds and shake my wheel pretty good. If that happened on the rear tire, I would feel it through the seat and the floor. I thought some kind of balancing issue happend and when I took it into a tire store for them to rebalance the tires, they found the big lump on the tire. Had to replace both fronts.
cwilson jr
Re: driving issues
December 04, 2008, 07:43:01 pm »
i thought i mentioned earlier that i eventually replaced all of the tires. i will try and get around to jacking it up this weekend and see if i find any play in the front wheels.
Re: driving issues
December 04, 2008, 07:51:15 pm »
you did but it can happen from just spinning tires taking turns to fast locking up the breaks
JRConnieK10
Re: driving issues
December 04, 2008, 08:34:48 pm »
I don't think you said if it is 2 or 4 wheel drive. If so I missed it. I had a k5 blazer that would shake out of control come to find out it was the ball joints didn't actualy figure out which one was bad I just chaged them all never happened again.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
cwilson jr
Re: driving issues
December 05, 2008, 09:55:19 am »
i don't believe i did say that. it is 4. now that you mention it, again i'm not real experienced in the suspension department, but ever since i've owned the truck it has made a pretty loud "clunk" from the rear end when i put it in gear. it is an auto as well if that helps.
JRConnieK10
Re: driving issues
December 05, 2008, 04:09:45 pm »
Well the clunk is more than likely its u-joints in the driveshafts.
BUILT NOT BOUGHT
cwilson jr
Re: driving issues
December 05, 2008, 05:20:55 pm »
and this would eventually cause it to ride rough like it is now?
driving issues
