Author Topic: Wider rear backspacing than 5 inches?  (Read 5218 times)
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« on: December 08, 2008, 08:01:46 pm »
My entire body is off....but, I cannot see why I couldn't run 6 1/2 to 7 inches of backspacing. It'll put the tires about 3/4 to 1 inch from the leaves.
Hasn't anyone done this? All I see here are 5 inch b.s recommendations. I'm planning to modify the tubs in the bed...so, why not?
If my thinking is corect, I should be able to run a 11 inch wide wheel with about 4 inches of "lip".
Any comments?
Re: Wider rear backspacing than 5 inches?
« Reply #1 on: December 08, 2008, 08:05:30 pm »
It will totally depend on the width of the wheel
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #2 on: December 08, 2008, 08:34:08 pm »
11 inches wide. 6 1/2 to 7 inches of backspacing. That puts about 4 1/2 to 5 inches on the front facing "lip" side. There's a ton of space behind the brake backing plate. A little E-brake cable mod and it looks like it should work.
Offline got2haul
« Reply #3 on: December 09, 2008, 06:40:50 pm »
When I was deciding on the wheel width/backspacing and tire combo, I thought about mini-tubbing the bed to fit a wider wheel/tire.  I took a lot of measurements, and I think your combo would work if you modify the inner bed sides like you said.  What size tire are you going to run?  Mickey Thompson 29x15.00R15 Sportsman S/R radial?  I think you've got enough room to do that.  12 inches (the overall width of an 11" wheel) minus 6 inches backspacing = 6 inches on the business side.  That's the same on the outside as mine with a 10 inch wide rim (11 inches minus 5 inches backspacing = 6 inches on the front side.)   Should work if you modify the wheel well.  Keep in mind that if you were to use the MT tire, the section width of that tire is 15 inches on a 12 inch rim ,so it would likely be only a little narrower on an 11 inch rim (maybe 3/8 to 1/2 an inch at the most) and you'd have to ensure the tire sidewall will clear any body or suspension parts.
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
« Reply #4 on: December 10, 2008, 12:17:53 pm »
You can make a carboard template to measure you optimum spacing, or you could make it out of plywood and make it really accurate.
I don't think 7" will work on the back, I think it would put the tire to close to the leaf spring.
