Wanting info on keeping or getting rid of egr? To keep or not to keep?
Topic: Wanting info on keeping or getting rid of egr? To keep or not to keep? (Read 7797 times)
jamnjc3
If you dont have 7 on the cover you aint $h!t! LOL
December 09, 2008, 05:53:22 pm »
Hey all. I am going to buy an intake manifold for my 75 C-10 454 automatic truck. Can I get rid of the factory egr system components? Will there be any adverse affects on the way it runs. Should I keep the factory egr stuff. I need to know before I can order an intake manifold. Please help. Thanks James
jefferias
Re: Wanting info on keeping or getting rid of egr? To keep or not to keep?
December 09, 2008, 07:04:54 pm »
i did a 350 swap and took out all the emmisions(use to have egr but no more, my intake came with a hole in manifold-edelbrock but also a block off for the egr . im runnin it blocked off) and she has never ran better. only thing i wish was better is the gas mileage but oh well its worth it hope it helps.
jamnjc3
December 09, 2008, 08:44:19 pm »
Thank you for the input. I would like some other oppinions also from others. Thanks James
TexasRed
December 09, 2008, 09:22:36 pm »
You may have to retard your timing some and you'd lose a wee bit of mileage but that's about it. Plus you lose the opportunity for your intake to get caked up from carbon as badly and getting the EGR stuck open.
December 09, 2008, 09:43:16 pm »
Are you building a performance engine and does it have to go through emissions?
jamnjc3
December 10, 2008, 07:34:45 am »
Its not super performance but it is a step above stock. It has a comp cams rv cam, lifters, springs, 3 angle valve job with manley keepers. Hooker headers and hooker mufflers. Now I am going to put an aftermarket intake on it. Edelbrock is the most obvious choice. But I am not sure wether to buy the Performer or Performer RPM. Only the Perfromer offers egr provisions but I really want to buy the Performer Rpm Air Gap. No the truck wont ever be emisions tested. I live in MD and if its 20 years old or older, you dont have to get it tested. Thanks again, waiting on more replys before I buy. Jamnjc3
JJSZABO
December 10, 2008, 07:56:15 am »
I removed the egr from my sons truck. I bought an Edelbrock Performer intake with egr provisions, but decided not to use it. I now have it blocked off - but it is there incase I decide to reinstall it.
You are correct about not requiring emissions if it is 20 years or older, but you have to tag it HISTORIC. Historic tags put restrictions on the amount you can drive it. Now I know the police don't actively stop historic taged vehicles, but they will give you a hard time about it if they pull you over for doing something squirrley ie... speeding, spinning wheels etc...
Currently, my sons truck is tagged HISTORIC - so far no problems.
Jeff
86 Chevy C-10
350, TH400
December 10, 2008, 08:00:05 am »
Then don't bother with EGR.
jamnjc3
December 10, 2008, 08:12:44 am »
Ok thanks. Im going to remove it! With the small mods done to the truck, do you all suggest Performer or Performer RPM?
jamnjc3
December 10, 2008, 08:15:48 am »
Mine is tagged Historic also. I have had over a dozen historic tagged cars and trucks and have never had one problem with the police, even when pulled over.
JJSZABO
December 10, 2008, 08:28:16 am »
That is good to know
My brother is a Frederick County sheriff's deputy and I hear the stories
Jeff
86 Chevy C-10
350, TH400
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
December 10, 2008, 08:33:03 am »
performer vs. performer rpm?
well i think this should be obvious. depends on what you want to do w/ it. What cam?
do you want an engine that screams up to higher rpms and get your peak there or do you want to take advantage of lower , or all range of rpms to get some good numbers?
I use the performer. i have an rv cam, therefore, see great numbers at the lower rpm range--i drive my truck and use it as a truck is intended. i pull with it. i have a 3.08 rear, so, the rpms will be in the lower range anyway and its street driven, not at the track. no sense to get the rpms up to the 4k range--no need for a high riser.
http://www.edelbrock.com/automotive_new/mc/manifolds/manifolds_main.shtml
Last Edit: December 10, 2008, 08:38:29 am by SgtDel
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
