Author Topic: 383  (Read 57829 times)
Offline hotrod24
383
« on: December 09, 2008, 11:51:26 pm »
well as some of you have herd i have a 383 thats been sitting for about 4 years and its been rained on and stuff but it has been covered up but what would be the first thing i would need to do i wanted to do a whole rebuild.
1978 pontiac grand prix...
Re: 383
« Reply #1 on: December 10, 2008, 06:46:34 am »
Put it on a stand and tear it down for inspection/measurements.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: 383
« Reply #2 on: December 10, 2008, 06:59:40 am »
the first part of a rebuild is to tear down the engine.   send the block to get it magnafluxed and/or bored.  order parts depending on how much  bored. Send heads out for valve/seals.  Get all parts back at about the same time and have fun with a toque wrench. Nuttin to it, huh?
« Last Edit: December 10, 2008, 07:02:39 am by SgtDel »
Offline hotrod24
Re: 383
« Reply #3 on: December 10, 2008, 03:41:15 pm »
that is what i thought i just did not know if it was worth do it because it has sit in the weather for so long
and it is pretty corroded but i will tear it down and see what i have thanks
« Last Edit: December 10, 2008, 05:53:38 pm by hotrod24 »
Offline hotrod24
Re: 383
« Reply #4 on: December 10, 2008, 06:28:53 pm »
where would be the best place to get 383 parts i know there is jegs and summit and gm performance parts would that be it?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: 383
« Reply #5 on: December 10, 2008, 07:46:18 pm »
all the above
Offline hotrod24
Re: 383
« Reply #6 on: December 11, 2008, 04:09:39 pm »
well i was down there so i thought i would snap a couple of pics i wish i would have not took the carb off
« Last Edit: December 11, 2008, 04:11:24 pm by hotrod24 »
Offline hotrod24
Re: 383
« Reply #7 on: December 11, 2008, 05:35:56 pm »
believe or not but this motor sounded goooood
Offline JJSZABO
Re: 383
« Reply #8 on: December 11, 2008, 07:02:18 pm »
That doesn't look too bad - I've seen junk yard motors much worse than that brought back to life ;D
I would use a new intake though
Jeff
86 Chevy C-10
350, TH400
Offline hotrod24
Re: 383
« Reply #9 on: December 11, 2008, 07:58:00 pm »
yea i am going for a edelbrock intake
Re: 383
« Reply #10 on: December 11, 2008, 11:14:43 pm »
You can clean all of that up. Send your parts to the machine shop for a hot tank and bead blast the intake.
Offline hotrod24
Re: 383
« Reply #11 on: December 11, 2008, 11:51:35 pm »
cool thanks vile i hope it all turn good
Offline hotrod24
Re: 383
« Reply #12 on: December 25, 2008, 12:37:12 am »
i think it takes a 400 crank to make a 350 a 383 so could i make this 383 a 396 some how?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: 383
« Reply #13 on: December 25, 2008, 01:14:45 am »
Quote
A 400 c.i. Crank and a matching 400 c.i. flex plate/flywheel.  There is also a minor thing about the piston rods needing milling or shaved slightly for clearance.  They sell these complete sets from summit or jeg's.
Offline joesgarage71
  • Wrench
Re: 383
« Reply #14 on: December 25, 2008, 09:13:20 am »
Quote
Clearance the block for the rods and use a small base circle cam
