Author Topic: fuel cell  (Read 38064 times)
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #15 on: December 11, 2008, 01:37:02 pm »
Tough times ahead. Sorry to hear about your job.
Yeah it sucks to be unemployed but they are going to send me back to school, so after 12 years I am going to try and make something of myself.
Offline silvrbreez
Re: fuel cell
« Reply #16 on: December 11, 2008, 01:44:27 pm »
If you had to venture to guess, would you be able to recall how much that setup set you back.
I'm trying to weigh between this setup and the 19 gallon aluminum tank that someone makes for the same area.
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #17 on: December 11, 2008, 01:56:01 pm »
Fuel cell, fuel lines, all the fittings and the diff cover about $400 I dont remember how much the aluminum tank was but I think that is why I went the route I did.
Offline silvrbreez
Re: fuel cell
« Reply #18 on: December 11, 2008, 02:09:08 pm »
Not bad at all.
I'm see it'd be about $450 for the 19 gallon aluminum tank. $50 for the GM sending unit.  And then whatever it would cost for the new lines.  Probably somewhere about $550 I'd guess vs. $400 this way.  I don't know, might be worth it to me for the extra 3 gallons.  I'm gonna have to think about it.
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #19 on: December 11, 2008, 02:16:47 pm »
Not bad at all.
Yeah my 350 drinks gas like its free :(  sometimes I wish I had a bigger tank
Offline 1983stepside
Re: fuel cell
« Reply #20 on: December 11, 2008, 02:37:37 pm »
thanks for the info i bet ill have the same problem with keeping gas in my cell when my truck is done 8)
Re: fuel cell
« Reply #21 on: December 11, 2008, 04:25:52 pm »
I used a Blazer tank in mine with 28gallon capacity:
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #22 on: December 12, 2008, 07:09:22 pm »
That blazer tank looks great!  Is that the spare tire carrier you used for the front crossmember?
Offline jhln8c
Re: fuel cell
« Reply #23 on: December 12, 2008, 07:19:51 pm »
Did you put a return line on your fuel cell?
Offline HAULIN IT
Re: fuel cell
« Reply #24 on: December 12, 2008, 08:34:13 pm »
69byrd, Your fuel cell is really in your truck backwards. Being gravity fed, it won't be a problem until your down to a quarter tank or so, but going up a hill or on a heavy launch (for very long), I think you will find problems. Does it have foam in it? Lorne
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #25 on: December 12, 2008, 11:17:53 pm »
No my fuel cell doesnt have a return line and yes it is foam filled.  I have not had any problems with it yet but I dont drag race.  I started to put it in the other way but I dont race so I didnt think it would be a problem.  If it starts to give me trouble I will turn it around.
Offline HAULIN IT
Re: fuel cell
« Reply #26 on: December 14, 2008, 07:51:34 pm »
Here's a few photos of mine. Basically, the same idea as the Capt's. Blazer install, but with a Summit/Jeg's 19 gal. aluminum cell. I moved the rear crossmember back, moved the spare tire carrier foreward for the front hanger. I made my own straps. The filler door would need to be a little different for the stepside, but the rest would apply. If you plan to ever go play at a sanctioned race track, be sure to have a skid plate on the bottom & a ground strap if you use a plastic cell. Lorne
Re: fuel cell
« Reply #27 on: December 15, 2008, 11:22:15 am »
The spare carrier was used at the upper support for the tank to "pull" up to.  The rear crossmember was moved back to the rear of the frame and angle iron was used for the front location of the factory straps.
Re: fuel cell
« Reply #28 on: December 15, 2008, 03:39:32 pm »
thanks for the info haulin it hey i saw your plate is a pa plate where about are you from in pa just curious dont have to answer  ???
Offline HAULIN IT
Re: fuel cell
« Reply #29 on: December 15, 2008, 04:08:44 pm »
I'm in Beaver Falls...I didn't see where you were from until you asked, I've been to/through Slippery Rock now & then over the years. Lorne
