Author Topic: fuel cell  (Read 38062 times)
Offline 1983stepside
fuel cell
« on: December 10, 2008, 07:06:00 am »
putting a fuel cell in my stepside undre the bed any pics or ideas would be great thanks
Offline JJSZABO
Re: fuel cell
« Reply #1 on: December 10, 2008, 07:59:41 am »
Jeff
86 Chevy C-10
350, TH400
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #2 on: December 10, 2008, 04:01:52 pm »
The fuel cell in that link looks like mine lol.  I also put mine under the bed and it was really easy.  I used a summit fuel cell and that same filler.  I used a piece of angle iron for the front crossmember the main thing is to make sure it is level.  The only problem I have had is I can keep gas in it ;D  Here is a couple pix.
I dont know what those bottles are doing there we must have been taking a break lol.
Offline ccz145a
Re: fuel cell
« Reply #3 on: December 10, 2008, 05:12:08 pm »
Quote
At my place, those would have been beer cans. ;D
Offline team39763
Re: fuel cell
« Reply #4 on: December 10, 2008, 06:01:01 pm »
I had problems with my diff cover rubbing my fuel cell under the bed.  It's an aftermarket cover with raised fins, so probably why it rubbed.  I also couldn't reach the upper bolts on the diff cover without removing the cell.  I ended up moving mine inside the bed for now.  And mine is a fleetside, so it might be a bit different.
Re: fuel cell
« Reply #5 on: December 11, 2008, 07:19:45 am »
thats a nice clean install it looks factory did you run in to any problems? did you cut a hole in a plank in the bed for the filler neck or does a plank flip up?
Re: fuel cell
« Reply #6 on: December 11, 2008, 08:04:54 am »
Me too!
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #7 on: December 11, 2008, 08:59:26 am »
Quote
It was early in the morning we try to not start drinking until after 12 ;)
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #8 on: December 11, 2008, 09:03:42 am »
The only problem I had was the brake line and it wasnt really a problem.  I just bent it to keep it from rubbing the fuel cell.  Right now I dont have a bed floor in the truck but the filler will sit in the middle of a plank and I am going to flush mount a billet fuel door in it.
Re: fuel cell
« Reply #9 on: December 11, 2008, 09:05:45 am »
ok cool when you do that can you post some pics cuz this is what i wanna do with my truck thanks
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #10 on: December 11, 2008, 09:10:36 am »
Did you use the stock rear crossmember to mount to?  I also have the diff cover with the raised fins and I have about 4 and 1/2 inches of clearence. Heres a few more pix. You can also see my fuel filter in these pix.
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #11 on: December 11, 2008, 09:12:57 am »
It may be awhile because I have been laid off from my job but I will post pics when I do it.
Offline ccz145a
Re: fuel cell
« Reply #12 on: December 11, 2008, 10:39:08 am »
Tough times ahead. Sorry to hear about your job.
Re: fuel cell
« Reply #13 on: December 11, 2008, 11:43:27 am »
ok nthanks and i no what ya mean we are real slow at work so theres been a hault in building mine as well but i was gonna use the rear cross member as a mounting point just wasnt sure bout the rest where did you find that rear end cover? is your cell a 16 gall cell? thanks for the pics i cant wait to see your truck done and mine to :o
Offline 69byrd
  • Haulin!
Re: fuel cell
« Reply #14 on: December 11, 2008, 01:32:34 pm »
The rear diff cover and the fuel cell both came from summit.  The fuel cell is a 16 gallon the only problem is I cant keep gas in it with my heavy right foot :o
