Author Topic: 2 Door Questions  (Read 13165 times)
Offline Thermal Izod
2 Door Questions
« on: December 11, 2008, 05:03:18 am »
Well, I'm trying to change out my hinge pins....they appear to be bucked at the bottom.  The nipple has 2 flat spots on it, and a wad of metal up by the hinge itself by both flats....how, with hand tools, do i go about getting these out?  I can't tell if it's got a c-clip on it or what, but it appears to be kinda bucked to hold it there....?
the other is, i'm gonna refinish my interior door panels...how do i get the window crank handle off?  thanks for your help!
« Last Edit: December 11, 2008, 05:18:31 am by Thermal Izod »
1982 Shortbed K10 Silverado.  305 ci with a mild cam, full true dual exhaust (Long tube headers, "H" pipe, and Thrush Turbo mufflers.  4x4, and otherwise completely stock.  about 153,000 miles.
Re: 2 Door Questions
« Reply #1 on: December 11, 2008, 07:06:03 am »
You need to remove the clip (the jesus clip) behind the crank.
Either use the tool or a pick tool to pop it off. Also a paint can opener ground to a point works mint.
If there are retainers on your pins remove them and drive them out. If someone modified them you may have to cut them off and get replacements
« Reply #2 on: December 11, 2008, 07:32:58 am »
thanks vile!  might be able to dremil them a little to knock them out...
Offline JJSZABO
« Reply #3 on: December 11, 2008, 08:17:59 am »
Vile:  Is that the REAL name for that clip - the jesus clip?  Or is it named that way, because, that is what you say when you are trying to remove it? :D
Thermal Izod - I use a thin rag to slip behind the window crank and "catch/push" the clip out.  A trick I learned from the audio folks.
I removed my hinge pins by cutting the pins with a reciprocating saw and using a long metal punch to hammer the two remaining pieces out.  I did this with the hinges removed from the vehicle.
Jeff
86 Chevy C-10
350, TH400
Offline ccz145a
« Reply #4 on: December 11, 2008, 08:53:57 am »
Quote
No, that's what you say after you remove it, and it goes flying off somewhere ;D
« Reply #5 on: December 11, 2008, 04:09:06 pm »
hahaha, ok i got the hinge pins done today.  I had to remove the door to make room to bang out the pins.  you can see in my pics, it looks like they used an air chisel to create a flange to hold them in.  I was able to beat the top one out with a hammer, but the tabs on the bottom one needed to be dremiled down so i could pound it out.  the bushing pictured was the best of the four that were in there...unreal.  it's like a new door, no sag, closes 100X's easier.  It still takes a little swing to close it, but not the SLAM it used to.  Barely had to adjust the striker at all...Also note the wear grooves on the pins themselves.
Offline Dragon
« Reply #6 on: December 13, 2008, 01:32:08 am »
Quote
LOL Yes, and that is also what you say when they are causing you trouble reinstalling the handles as well....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
« Reply #7 on: December 13, 2008, 03:58:42 pm »
ok, got the door panels off and painted today.  any tricks to get the window crank jesus clips back on w/o scratching up my fresh door panels?  i got 'em off with a thin screw-driver....
Offline dv8customs
« Reply #8 on: December 13, 2008, 05:45:22 pm »
Put the clip back on the window crank first. Then just pop the crank on.
Offline 69byrd
  • Haulin!
« Reply #9 on: December 13, 2008, 07:07:53 pm »
Quote
I always had a few other choice words for them ;D
« Reply #10 on: December 14, 2008, 11:09:26 am »
http://en.wikipedia.org/wiki/Jesus_clip
Personally I call them that when they go flying and I can't find them and start cussing like on friday when I lost a snap ring. I bought a snap ring kit for 5 bucks thank jesus I had it lol
