Author Topic: 79 Chevy K20  (Read 26267 times)
79 Chevy K20
« on: December 12, 2008, 11:58:40 pm »
This Pic i was stuck because my 4x4 was only 4x2 the rear was hung up on a rut that my 38 swampers couldn't touch having a problem with keeping the front driveshaft bolted in keeps vibrating the bolts out and then snapping the last one. I'm thinking tread locker low strength but anyone else got any ideals. oh yeah the hood was off due to an engine swap
Offline Dragon
Re: 79 Chevy K20
« Reply #1 on: December 13, 2008, 12:38:16 am »
Don't haven any suggestions Sorry, but I wanted to say Truck looks Good with Shaved Handles, and Oddly I happen to like the "Mud Hue" Rear ;D
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Re: 79 Chevy K20
« Reply #2 on: December 13, 2008, 06:12:49 am »
Lol Ty
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: 79 Chevy K20
« Reply #3 on: December 13, 2008, 04:19:21 pm »
Threadlocker sounds good, try it and keep a close eye on it.
Re: 79 Chevy K20
« Reply #4 on: December 15, 2008, 11:33:26 am »
The bolts to the yoke?  Are you using lock washers?
Re: 79 Chevy K20
« Reply #5 on: December 16, 2008, 04:01:06 pm »
lol i knew i forgot something. but um no lol forgot all about them used washers tho just not lock. its a pain to reach up to the trainsfer case to reach the yoke up there.
Offline oldwhity
Re: 79 Chevy K20
« Reply #6 on: December 19, 2008, 04:40:27 pm »
Hey Irish, nice truck. 38's, trimmed fenders, how much lift?
Rob G.
81 Chevy K20 4x4 LWB stepside
Re: 79 Chevy K20
« Reply #7 on: December 19, 2008, 11:06:18 pm »
it's 6 and 3
Offline oldwhity
Re: 79 Chevy K20
« Reply #8 on: December 21, 2008, 11:29:51 am »
Looks great. Does it rub in the front while wheeling and turning? Is your gas door on the other side or did you shave that too?
Rob G.
Offline GP3624
Re: 79 Chevy K20
« Reply #9 on: December 21, 2008, 11:50:27 am »
Make sure that the yoke caps are aligned on both ends, sometimes when a shaft is extended due to a lift the ends are out of sync and will cause enough vibration to loosen the bolts. Lock washers and locktite is always good.
Offline CruzinHigh
  • Chevy 4 life
Re: 79 Chevy K20
« Reply #10 on: December 21, 2008, 12:38:52 pm »
Great photo!  Did you have the front driveshaft lengthened?
Mike Carter
1986 Chevy K-10 4x4
Re: 79 Chevy K20
« Reply #11 on: December 22, 2008, 11:54:12 pm »
the bed is off a newer pick up like mid 80's the door is on the other side tho.
the tires don't even come close to rubbing, the shaft shouldn't have to be extended in less the lift is over 6 in the suspension if I'm not mistaken.
Offline Igosplut
Re: 79 Chevy K20
« Reply #12 on: December 23, 2008, 05:06:56 am »
Look at the shaft and see if the center yoke is hitting the stops on the inside of the CV. If it is then you have to change the angle of the shaft
Re: 79 Chevy K20
« Reply #13 on: December 23, 2008, 06:42:01 am »
Make sure there is enough travel in the slip yoke, yes use loctite, and make sure your u-joints fit correctly.
Re: 79 Chevy K20
« Reply #14 on: December 23, 2008, 08:56:42 am »
I was told that I needed to not only have my front shaft lengthened on the truck, but also add a cv joints to the opposite end of the double joint. I have an inlaw that works for a drivetrain company so I was going to get them to lengthen the rear shaft as well.
