Author Topic: My Edelbrock Carb!  (Read 22335 times)
Offline unbludictable
  • Low Down Blu
My Edelbrock Carb!
« on: December 16, 2008, 04:53:03 pm »
I have a used Edelbrock Preformer on my '76 GMC. I have a rebuilt 350 engine and this edelbrock carb is not keep it's prime!
Re: My Edelbrock Carb!
« Reply #1 on: December 16, 2008, 06:34:06 pm »
Offline grinder1989
« Reply #2 on: December 17, 2008, 01:58:17 am »
I'm having a problem with mine as well.  It idles fine but if I stomp on it and a dead stop, it just bogs and the engine really doesn't do anything until I let off the gas a bit then it takes off.  I'm thinking it's the jets but I'm not sure, I've never had to tune a carb before :(.
Sundown Authorized Dealer, Akron OH
« Reply #3 on: December 17, 2008, 05:22:05 am »
Check the accelerator pump and stroke. It's adjustable on yours. Try playing with the settings and make sure you have no kinked fuel lines first.
Offline grinder1989
« Reply #4 on: December 17, 2008, 10:06:50 am »
New accelerator pump.  I think I have a kink in the metal fuel line, though it doesn't look that bad.  I'll have to get that checked out.
  • Low Down Blu
« Reply #5 on: December 17, 2008, 04:25:12 pm »
How can I tell if it's the fuel pump or the accelerator pump? It turns over and runs fine when it finally runs, but after it sets over night, I have to pour gas in the carb for it to run! I tried patting my accelerator before starting it, but that doesn't help!
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #6 on: December 17, 2008, 05:14:31 pm »
That sounds like mine when the fuel pump was bad.  The diaphram started leaking and it would let the gas run back into the tank and suck the float bowl dry.
Offline grinder1989
« Reply #7 on: December 18, 2008, 10:41:49 pm »
Had a kink in the gas line.  I installed a new fuel pump, rubber lines and a fuel filter.  Seems to run 10 times better.  Thanks for the tip.
Offline grinder1989
« Reply #8 on: December 19, 2008, 04:12:06 am »
A little update.  After I fixed my little problem, I managed to spin one of my tires with 500 pounds of tube sand and snow tires on the back from a dead stop without brake torquing.  It made me happy lol.  ;D
« Reply #9 on: December 19, 2008, 10:14:02 am »
Glad to hear
