Author Topic: Cam Suggestion  (Read 36960 times)
Offline grinder1989
Cam Suggestion
« on: December 16, 2008, 10:52:42 pm »
I just had a new 350 built for my truck.  The valve springs can handle .450 inches of lift.  I was told to go with a 220 duration cam with not too much more than .450 lift.  I'd like to get that choppy idle sound but I don't want to sacrifice low end power.  Any suggestions?
Sundown Authorized Dealer, Akron OH
Re: Cam Suggestion
« Reply #1 on: December 17, 2008, 05:23:35 am »
More details on the application. What's it going in, transmission, tire size, exhaust, intake, intended useage?
Offline camdenoilchange
Re: Cam Suggestion
« Reply #2 on: December 17, 2008, 07:28:26 am »
if your just looking for the "choppy sound", get one of those crane thumper cams. You pretty much get the sound without having to run a big stall and stuff. Here's a link for you to hear.
http://www.youtube.com/watch?v=KT9gor9gP7o&feature=related
« Last Edit: December 17, 2008, 07:32:43 am by camdenoilchange »
Offline grinder1989
Re: Cam Suggestion
« Reply #3 on: December 17, 2008, 10:04:55 am »
1974 chevy c10, turbo 350, tire size will change but they're a goofy size.  its like 30 by something....I have to go check the side wall.  They're good sized tires.  30 something x 10 by 15 Headers, Wieand Single plane manifold...I just want a nice running street truck that will take a visit to the drag strip.
Re: Cam Suggestion
« Reply #4 on: December 17, 2008, 10:36:48 am »
Why did you chose a single plane intake manifold?
Offline grinder1989
Re: Cam Suggestion
« Reply #5 on: December 17, 2008, 10:40:44 am »
$45  ;D That's why haha.  I'm going to end up running it.
Offline eventhorizon66
Re: Cam Suggestion
« Reply #6 on: December 17, 2008, 10:46:08 am »
You can modify a single plane with a divider to improve booster signal.  But it won't have the same low end response as a 180* dual plane.
'85 C10 SWB 350 700R4 TKO600
Offline grinder1989
Re: Cam Suggestion
« Reply #7 on: December 17, 2008, 10:52:59 am »
That's ok, I can always change the intake, but it's all I have right now and money is tight.  I have $200 for a cam and lifters and that's it.
Re: Cam Suggestion
« Reply #8 on: December 17, 2008, 11:00:39 am »
Well regardless of the size you pick, Summit offers cam/lifter kits for about $90.  And I'll bet Vile's gonna recommend a cam from them too, as he often does.
So that leaves enough money to sell the Weiand and pick up a nice used dual plane on eBay or Craigslist.  Of course, this is assuming that you won't need the rest of that money to replace valvesprings, seals, etc.
« Last Edit: December 17, 2008, 11:03:35 am by eventhorizon66 »
Offline frogman68
Re: Cam Suggestion
« Reply #9 on: December 17, 2008, 11:04:03 am »
Offline grinder1989
Re: Cam Suggestion
« Reply #10 on: December 17, 2008, 11:07:38 am »
Everything on the engine is new.  I haven't had the cam installed yet but it has rebuilt heads.  Valves, Valve springs etc...The springs can handle .450 lift so I want a cam that can do around that.  I will not run any summit part in my engine.  I'd rather spend the extra money for a Comp Cams.  I should also point out I'm looking for a hydraulic cam.  I'm probably not going to replace that intake but I'll check craigslist.
Offline DnStClr
Re: Cam Suggestion
« Reply #11 on: December 17, 2008, 11:32:40 am »
Quote
Intriguing statement since you live so close to Summit Racing. What happened? Did you get some bad parts?
Don
87 Chevy Silverado
Re: Cam Suggestion
« Reply #12 on: December 17, 2008, 11:33:56 am »
Well if you are hung up on brand names the ISKY Mega 264 comes to mind.  It won't have a choppy idle, though.  And I wouldn't run it with less than 8.5:1 CR (9:1 would be better).  But my advice is based on my comprehension of David Vizard books and magazine articles, not hands on experience, so keep that in mind.
Offline grinder1989
Re: Cam Suggestion
« Reply #13 on: December 17, 2008, 11:36:08 am »
Summit racing has terrible customer service and I've heard many horror stories of their name brand parts ruining good engines.  I would much rather stick with a name I trust.  The engine should have a 10 to 1 compression ratio.  I'm looking for the lopey idle, but I don't want it to the point where I'll loose a lot of my low end power.
Re: Cam Suggestion
« Reply #14 on: December 17, 2008, 11:55:06 am »
Well with 10:1 you could go a bit larger without loosing much low-end.  Maybe an Isky Mega 270 or Comp Magnum 270, but these cams have .465" and .470" lift, respectively.  Are your lift restrictions based on spring pressure or coil bind?
